KB9LOR
WH Fuel Cock
KB9LOR
Got my Raider 12 out today, went to start it and not getting fuel, well not enough, but anyways it is not unpluggable nor usable, have looked high and low for info on a replacement, with no luck, has anyone replaced one before? and if so got a part number?
sorekiwi
What I have done in the past is to remove the little gauze filter on the petcock, and then used an inline filter to catch all the crap in the tank.
I think the Raider uses the steel rectangular fuel tank? If so, you can grab the gauze screen with a pair of needle nose pliers thru the filler hole.
Napa sells a fuel tank petcock with an 1/8 pipe fitting. I'll try to find the number over the weekend.
KB9LOR
Thanks! Yes it does have the rectangle fuel tank, I did take the scrren off and put a inline filter, it helped but still not enough flow, so going to replace it.
