dyt4000 2 #1 Posted April 21, 2010 Will a spec 30507D work in place of the original 30108D? Both are K181 engines. Share this post Link to post Share on other sites
rmaynard 16,836 #2 Posted April 21, 2010 What do you want to put it on? Share this post Link to post Share on other sites
rmaynard 16,836 #4 Posted April 21, 2010 According to the book that I have on Kohler, the 30507D is for a John Deere 110. I don't know if it can cross over to your 857 or not. Sorry I don't have more info. I'm sure that one of the other members will be able to shed more light on the subject. Bob Share this post Link to post Share on other sites
W9JAB 156 #5 Posted April 21, 2010 Take a look at this, http://www.mywheelhorse.com/graphics/file/..._Model_List.pdf Share this post Link to post Share on other sites
Raider12 14 #6 Posted April 21, 2010 Take a look at this, http://www.mywheelhorse.com/graphics/file/..._Model_List.pdf Hey, thats a nice bit of info to have on hand. Thanks for sharing. :omg: Share this post Link to post Share on other sites
dyt4000 2 #7 Posted April 21, 2010 Nice list, but how does that help me? Share this post Link to post Share on other sites
rmaynard 16,836 #8 Posted April 21, 2010 From what I can see, the chart indicates that the 30507D is not a Wheel Horse engine. Even though both are K181 engines, the mounting holes for hardware may be different or missing. You are having the same difficulty as I am. I'm trying to determine if any engine other than a K301S-47421D 12HP engine will fit perfectly on a 1977 C-120 8-Speed. Bob Share this post Link to post Share on other sites
rickv1957 77 #9 Posted April 21, 2010 Take a look at this, http://www.mywheelhorse.com/graphics/file/..._Model_List.pdf Great info there,thanks much!,Rick Share this post Link to post Share on other sites
pfrederi 19,729 #10 Posted April 22, 2010 Nice list, but how does that help me? Problem is Kohler made hundreds of different spec K181s. it is unrealistic to expect anyone (even at Kohler, let alone here) would know what spec #s could be interchanged/substituted. What you need to do is look up both spec numbers on the kohler site and start comparing part numbers on some key parts. Most likely differences would occur in the oil pan that would impact mounting...but would be an easy swap from your current motor if the connecting rod was the same number (long and short dipper issue potential) Also the crankshaft is most likely different. Issue of length on PTO end you probably could use your existing crank if the John deere one is too short. Electrical system could be completely different/...Mag vs battery ignition but that would be a surmountable (but not super easy problem Share this post Link to post Share on other sites
dyt4000 2 #11 Posted April 29, 2010 Good news! I scored a correct WH K181 for my tractor! Happy days are here again! :omg: Share this post Link to post Share on other sites
rmaynard 16,836 #12 Posted April 29, 2010 Always nice to find just what you are looking for. Bob Share this post Link to post Share on other sites
