Countdown To Christmas!
jimbotelho
753 PARTS
jimbotelho
i HAD POSTED THAT i NEEDED A LIFT ASSY FOR MY 753. AFTER CLOSER EXAMINATION i THINK i ONLY NEED THE INSIDE GUTS TO THE LIFT HANDLE MAINLY A SPRING? ALL PARTS SEEM IN TACT BUT THE TOP (BUTTON) DOES NOT POP BACK iM ASSUMING ALL THAT IS IN THE HANDLE IS A ROD AND SPRING A LITTLE HELP GUYS THANKS
clintonnut
It is just a simple compression spring you can get at TSC. Just lube up your lock rod. There is a centering cap on the top of the rod that is under the grip. If the rod is rusty it will not slide through the centering cap.
Charlie
KC9KAS
Had the same problem last weekend. My handle needed some welding, so I took it apart, cleaned it up and greased it up and now it is as good as new!
jimbotelho
anyone have an exploded view picture of the complete lift assy?
