jimbotelho 1 #1 Posted April 20, 2010 i HAD POSTED THAT i NEEDED A LIFT ASSY FOR MY 753. AFTER CLOSER EXAMINATION i THINK i ONLY NEED THE INSIDE GUTS TO THE LIFT HANDLE MAINLY A SPRING? ALL PARTS SEEM IN TACT BUT THE TOP (BUTTON) DOES NOT POP BACK iM ASSUMING ALL THAT IS IN THE HANDLE IS A ROD AND SPRING A LITTLE HELP GUYS THANKS Share this post Link to post Share on other sites
clintonnut 127 #2 Posted April 20, 2010 It is just a simple compression spring you can get at TSC. Just lube up your lock rod. There is a centering cap on the top of the rod that is under the grip. If the rod is rusty it will not slide through the centering cap. Charlie Share this post Link to post Share on other sites
KC9KAS 4,745 #3 Posted April 20, 2010 Had the same problem last weekend. My handle needed some welding, so I took it apart, cleaned it up and greased it up and now it is as good as new! Share this post Link to post Share on other sites
jimbotelho 1 #4 Posted April 21, 2010 anyone have an exploded view picture of the complete lift assy? Share this post Link to post Share on other sites
