rodco 0 #1 Posted April 20, 2010 I was taking apart my C-161 Auto tractor today and noticed that the Drive belt to the Hydro transmission is resting on the Transmission filter. It does not seem to have worn anything, but I was curious as to if this was normal. Should the belt be tightend. I am planning on changing the filter this week and want to make sure it won't be damaged. ROB Share this post Link to post Share on other sites
Shuboxlover 481 #2 Posted April 25, 2010 Is this a new tractor to you? or have you been using it like this? Share this post Link to post Share on other sites
rickv1957 75 #3 Posted April 25, 2010 It is possible for belt to rub filter when drive is disengaged,Rick Share this post Link to post Share on other sites
KC9KAS 4,744 #4 Posted April 25, 2010 Is your parking brake on or off in the picture? If is off, I would say there is too much play and the belt should be replaced. If it is on, the belt is loose due to the idler pulley NOT being held tight to the belt. Share this post Link to post Share on other sites
