worzel gumage 0 #1 Posted April 19, 2010 went to start my wheelhorse the other day and it started briefly then wouldn't start and when i try to start it a clicking sound comes from the solenoid , the starter does not turn and lights do not come on etc, its died . should i start with the solenoid ? any help would be appreciated Share this post Link to post Share on other sites
W9JAB 156 #2 Posted April 19, 2010 :omg: Start with the Batt. Share this post Link to post Share on other sites
Save Old Iron 1,573 #3 Posted April 19, 2010 You can fix a problem by troubleshooting or guessing. Which method do you want to use to fix this problem? 1 Share this post Link to post Share on other sites
worzel gumage 0 #4 Posted April 19, 2010 its not the battery as its charged Share this post Link to post Share on other sites
worzel gumage 0 #5 Posted April 19, 2010 i am no mechanic so any advice welcome Share this post Link to post Share on other sites
pfrederi 19,253 #6 Posted April 19, 2010 You could always use the old Army Motor Pool approach. Truck won't start... Replace batteries Still won't start replace starter motor Still won't start replace solenoid still won't start replace switch still won't start Turn the da*n thing in... My thought you can trust your mother but you can never trust your ground!! Clean your battery cable terminals and teh ground connection to the frame. Do you have a multi meter??? Share this post Link to post Share on other sites
Save Old Iron 1,573 #7 Posted April 19, 2010 We are going to need a little more info - as Paul asked - do you have any tools to troubleshoot electrical issues , meters, test lights, etc. The talent here varies greatly and we don't want to overrun a "non-mechanic" with too much info, but we do need to know what you tasks your comfortable with. Sometimes the best ( least expensive ) advice you can give someone is "take it to the shop" Let us know what your level of expertise is. An now for my motivational poster of the week ..... 1 Share this post Link to post Share on other sites
Don1977 605 #8 Posted April 20, 2010 I don't know how you tested the battery for voltage. You can test for 12 volts but with out a load tester it still may not have enough power to start. Try jumping it with another good battery. Share this post Link to post Share on other sites
W9JAB 156 #9 Posted April 20, 2010 you said no lights, thats why I said check the batt. do you have any fuse off the batt? The next thing would be the ing. switch. Share this post Link to post Share on other sites
