Michael Bullington 5 #1 Posted April 14, 2010 okay a couple of items: 1.) the pto lever has a spring..one side hooded to the rod...I cant remember or see any place to put the other end of the spring. 2.) my saftey switch has two switchs (im not sure why?) but one of the metal contacts are broke off the top switch,,,can u still get these? 3.) also speaking of saftey switch my seat is broken also? p.s i should have took better notes stripping this thing! thanks for all replies Michael Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted April 15, 2010 I sent you the wrong way on the spring, Michael. (and I finally found the pictures) There are two PTO lever safety switches because one is in the starter circuit (engine won't crank unless PTO lever is disengaged) and the other switch is in the ignition circuit (works in conjunction with the seat switch to kill the engine when no operator is seated ~ but only when PTO is engaged) P/N for the switches at the lever (both are the same) is 111332. The seat switch should be # 112418. Share this post Link to post Share on other sites
