Countdown To Christmas!
family tradition
raider 8
family tradition
just trying to figure out whether the starter is bad or the solenoid is bad.because it was unning before i came in for dinner. went back back out to start it to put it in the shed and nothing. starter wheel moved but didn't engage. any idea where i can get a starter and a rebuild kit . it goes on a 8 hp kohler.
rickv1957
If your starter is working but not engaging, lube the drive with a little wd40,Rick
family tradition
i would but i took the starter off i will spray some on there and hopefully that works . i priced a new one and it costs like 191.00 from the guy where i get my parts from
rickv1957
You can get a aftermarket starter online for 60.00 and they work good,Rick
family tradition
where at ? i'm looking now and haven't found one
algrc120man
if you have the kind of drive on your starter that has a rubber under the metal gear dont put lube around it if you do the lube will get between the rubber and metal and will slip kohler does not recomend lube in this area. if this is what is happening youll probably have to replace the drive which is around 60.00 from kohler stens may sell them cheaper but i dont have my book here. :omg:
