mowerman1193 42 #26 Posted April 15, 2010 Seems like you should be able to just use the hydro lift to set it where you like..Might be a little tricky at first but you will get used to it.. Kevin Share this post Link to post Share on other sites
jachady 130 #27 Posted April 15, 2010 It doesn't have a hydro lift, still a manual lift. Just got the hydro trans. Share this post Link to post Share on other sites
mowerman1193 42 #28 Posted April 15, 2010 Well in that case I would say you will need to get the dial-a-height parts and install that on the tractor..I had to do that on one of my tractors..You will either need to trim your lower dash and shift plate or find a factory one that is already trimmed for the dial-a- height.. Kevin Share this post Link to post Share on other sites
wh500special 2,435 #29 Posted April 18, 2010 Why would you prefer an 8-speed with a FEL? Not enough hands. On a manual transmission tractor your feet can control the stop/go motion of the tractor while you steer with one hand and run the loader hydraulics with the other hand. On a hydro - unless you've equipped it with a foot control - you can stop with the brake pedal, but you can't resume motion w/o putting a hand on the DCL. I don't currently have a loader, so don't have a horse in that race. i prefer the hydro for everything but tilling since the tiller seems to push my tractors since my ground is so hard. Reliability on either style correlates pretty well to how the tractor has been maintained. Steve Share this post Link to post Share on other sites
