porkchop 1 #1 Posted April 12, 2010 I got the new c175 out changed the oil to synthetic and added a 48" deck. The problem is the steering is nice and tight but it,s off a tooth or 2 on the gear and will not turn left as far as right, Whats the easiest way to move it a tooth??? Loosen the shaft or lift the steering wheel up??? :omg: Share this post Link to post Share on other sites
rickv1957 76 #2 Posted April 12, 2010 Randy,is steering fan gear centered when tires are straight?,Rick Share this post Link to post Share on other sites
clintonnut 127 #3 Posted April 12, 2010 Yea you might want to adjust your tie rods if it is off. Once you adjust I think there should be 1/8-1/4" of toe in measuring from the edge of the tire. Charlie Share this post Link to post Share on other sites
porkchop 1 #4 Posted April 12, 2010 The tires are straight but the gear is not centered. Share this post Link to post Share on other sites
rickv1957 76 #5 Posted April 12, 2010 Randy that would mean you will have to adjust out in tie rods or spindles have been bent,seen many,Rick Share this post Link to post Share on other sites
porkchop 1 #6 Posted April 12, 2010 Thanks Rick I,ll take a closer look tomorrow. Share this post Link to post Share on other sites
porkchop 1 #7 Posted April 12, 2010 Some one must have welded the rack gear to the steering shaft that go,s to the front with the wheels turned. That,s ok I have the parts to fix it and the motor and hydro are good. I just mowed the whole yard with it and it will be a good tractor with a little work and paint. :D Share this post Link to post Share on other sites
