bo dawg 518 #1 Posted April 10, 2010 What is the correct air filter in a tear drop breather style on the 82 C-175? Is it a short (not very tall) one? Right now the one thats in it can't be right, the cover doesn't go all the way down against the base. I cant find any info about it. :omg: Share this post Link to post Share on other sites
C-Series14 15 #2 Posted April 10, 2010 Let me go out and measure mine and look for numbers.... Share this post Link to post Share on other sites
C-Series14 15 #3 Posted April 10, 2010 3" tall with foam cover around it. Kohler part number is 45-083-02. Mine has a metal dish that goes over the top of the air cleaner sort of like a seal then the cover goes over the whole assembly. Share this post Link to post Share on other sites
bo dawg 518 #4 Posted April 11, 2010 3" tall with foam cover around it. Kohler part number is 45-083-02. Mine has a metal dish that goes over the top of the air cleaner sort of like a seal then the cover goes over the whole assembly. 3" would be taller yet, I have the tear drop style breather. The filter that's in it now is just a little over 2" and the top still doesn't go down to touch the base. :omg: Share this post Link to post Share on other sites
C-Series14 15 #5 Posted April 11, 2010 OK. Well, mine is an 84 with the tube for heat from the exhaust manifold so it must be different. Would have to see if I can find my original 1981 engine filter cover and see what it looks like. Share this post Link to post Share on other sites
bo dawg 518 #6 Posted April 11, 2010 OK. Well, mine is an 84 with the tube for heat from the exhaust manifold so it must be different. Would have to see if I can find my original 1981 engine filter cover and see what it looks like. Take a look at this pic and see if you can see the gap at the bottom between the base and breather cover. At least I dont think it should be like that. Share this post Link to post Share on other sites
gwgdog66 23 #7 Posted April 11, 2010 Air filter for that engine for 1982 is 47-083-01. Wix filter PN# is 42296, Height: 1.812, Outer Diameter: 7.000, Inner Diameter: 5.570. Hope this helps Share this post Link to post Share on other sites
