Countdown To Christmas!
62vetteefp
lawn Ranger will not start
62vetteefp
63 lawn ranger with 64 engine. Did run at one time but never well.
Have spark, have good gas, turns over great.
squirted gas in plug hole and still will not start.
Rebuilt carb but when it did not start installed new carb. Still will not start.
What do I look for next?
thanks
Gerry w
does yours have a shut off switch? If so could the ground be loose or the wire cut or shorted out?
62vetteefp
Has key. When key is on I have spark, when off no spark. So not an electrical issue?
rickv1957
Does compression seem ok?,Rick
62vetteefp
105 psi
rickv1957
Possibly your ignition timing is off,Rick
62vetteefp
OK, how do I check ignition timing? I know how to do it on a car and have a gun but where is the flywheel and everything else!!!!!!!
BPjunk
You can use a "timing light" to see if there is a spark when you "hear" the piston come up to TDC (with out the plug installed) but I would place money of the fact that the plug may be a bad plug.
Wild Bill
Coadster32
You could also pop off the flywheel and look to see if the key is sheered off.
oilcrazy
If it's a Champion plug, throw it away and try an A C or Bosch, I've had Champions right out of the box that wouldn't fire.
TheUnknownCat
Tune up. Points, plug, condenser, clean the coil and flywheel surfaces. Cheap enough, and it needs it anyway -whether it is this problem or not, probably is though. :omg:
pfrederi
Fly wheel Key First to evaluate. Then point gap. If you have spark then the points/condenser are probably OK. If the gap is way off it may affect timing but I am betting on the key
62vetteefp
Thanks guys, took the flywheel off and cleaned everything up. Put it back together and it now runs. did put a plug in it but that did not fix it. Thinks I will put the old plug back in and see if it runs, just to check.
