MaineDad 87 #1 Posted April 2, 2010 Can someone post a picture of a C-120 or C-160 PTO? I'm having trouble with my linkage. Share this post Link to post Share on other sites
MaineDad 87 #2 Posted April 2, 2010 Here's my problem. I think the Yoke is too small. Did they make different size yokes? I just got this PTO and lever today for the C-120, but it does not seem to fit. See picture; Share this post Link to post Share on other sites
rickv1957 77 #3 Posted April 2, 2010 Im thinking the yokes are the same,you need a hairpin thru yoke above lower mount to keep yoke in place,Rick Share this post Link to post Share on other sites
MaineDad 87 #4 Posted April 2, 2010 Rick, The Yoke does not go low enough on the bottom to get the hairpin in place. I centered the yoke with the PTO bell housing and it does not reach the bottom hole at all Share this post Link to post Share on other sites
rickv1957 77 #5 Posted April 2, 2010 What is overall length?,Rick Share this post Link to post Share on other sites
rickv1957 77 #7 Posted April 3, 2010 Mine is 12 1/4",is it possible that hoop is sprung a little,you should be able to tweek it back to length,everything else looks fine in your picture,Rick Share this post Link to post Share on other sites
dgoyette 12 #8 Posted April 3, 2010 Micah, Feel free to stop by and see the C160 if that will help. Should be home early morning but just call first to be sure Share this post Link to post Share on other sites
MaineDad 87 #9 Posted April 3, 2010 I'm not sure. If mine were the same length, than it would fit fine. Weird... Share this post Link to post Share on other sites
WH854 45 #10 Posted April 3, 2010 I think you have a short one I measured mine and one is 11 1/2 a junk one I have is like rick said 12 1/4. 1977 C120 and C160 both use the same p/n 102938. My 1981 C-105 uses P/N 106694. A 1981 C175 Twin call for P/N 106857. So I'm thinking there are different length hoops My C-105 moter does not bolt to the frame directly. It has mounting plate with a hole for the bottem of hoop to ride. Shaker Plates the call them. Hope this will help you. Chas Share this post Link to post Share on other sites
Kelly 1,037 #11 Posted April 3, 2010 Yes they made a few diff ones, I ran into that last year Share this post Link to post Share on other sites
gwgdog66 23 #12 Posted April 3, 2010 1975 C-160 Top Side looking down. I can get a picture of the lower side tomorrow. Share this post Link to post Share on other sites
MaineDad 87 #13 Posted April 3, 2010 Thanks guys. Yes this is the small hoop. There is no evident bend. Off to eBay unless someone has a hoop I can buy? Share this post Link to post Share on other sites
MaineDad 87 #14 Posted April 3, 2010 There are a couple on eBay right now. One for a 312-8 and one for a 520H. The 520H looks bigger than the 312-8... Share this post Link to post Share on other sites
wheelhorsec85 5 #15 Posted April 3, 2010 Yes they made a few diff ones, I ran into that last year they made as far as i no 3 different hoops . the lower end on yours is the short one you need a long one . ill check if you want and see if i have one jeff :omg: Share this post Link to post Share on other sites
