persof 14 #1 Posted March 31, 2010 I want to make a generator attachment for my 312-8 and I have some ideas on what to do but I would like to look at some detailed photos of a stock Wheel Horse setup first. And will also gladly look at your setup. Look at this link. http://www.vmisales.com/voltmaster_beltdriven/ab50.html Thanks Francis Share this post Link to post Share on other sites
Sparky-(Admin) 24,646 #2 Posted March 31, 2010 Heres a thread about my 4000 watt Generac unit mounted up to one of my Wheel Horse's. Theres a big knob like on a deck mule drive that I use to move the unit forward to put tension on the belt. The knob is under the power head, Mike........ http://www.wheelhorseforum.com/index.php?...12&hl=generator Share this post Link to post Share on other sites
persof 14 #3 Posted March 31, 2010 Sparky, Could you please send me a picture of the underside of the generator mounting frame (the part that I circled. Thanks Francis Attached Image Share this post Link to post Share on other sites
Wilsonrl48747 0 #4 Posted April 16, 2010 I found a generator on Criagslist that hooks into the mule drive tach a matic on the front. Have to remove the mule drive first, but it slides right in. I have a picture of it in a previous post, and I can take some more pictures if you are interested in seeing how they made the platform. The weight of the generator keeps tension on the belt. Pretty simple design and it works great. Had to use it once this winter to keep the basement from flooding when we were out of power. Here is the link to the original post http://www.wheelhorseforum.com/index.php?...topic=11163&hl= Share this post Link to post Share on other sites
Wilsonrl48747 0 #5 Posted April 21, 2010 I took some pictures of the mounting plate for my generator tonight so you could see how this one hooks up and was made. Share this post Link to post Share on other sites
Curmudgeon 28 #6 Posted April 25, 2010 I used to have one, here are a couple of pictures: It hooked into the front and mid hitches, the generator was bolted to a tilting part of the frame. Lift the generator up, put belt on, and let the weight of the generator hold the tension on the belt. Share this post Link to post Share on other sites
persof 14 #7 Posted April 27, 2010 thirdroc17, Could you please post a pic of the underside of your generator mounting frame? Thanks Francis I've copied your pic in my post, flip it over and take a picture. Attached Image Share this post Link to post Share on other sites
Docwheelhorse 2,875 #8 Posted April 29, 2010 HI--here is something I put together in a days time for a 3000 watt unit I had.... http://www.wheelhorseforum.com/index.php?...65&hl=generator Tony Share this post Link to post Share on other sites
