zach l
squeaky engine?
zach l
i have a k301 and if you turn it over by hand it has a squeak any ideas?
rickv1957
Does engine run OK?,Rick
zach l
i have no idea i wanted to find the problem before i tried to get it running
Buzz
Did you check to see if any of the engine's sheet metal was rubbing on the flywheel or shafts? :omg:
zach l
i took all the sheat metal off of it. it doesn't squeak the whole rotation either im puzzled :omg:
TT
Remove the dipstick and try it.
Raider12
Ok, I gota ask. Is there oil in it? I know this is a simple tast but, sometimes it's the simplest things we can over look.
Has been stting for a long while without being run? Or maybe you don't know the history?
Denver
zach l
i have no idea on the history of it but the way the inside looks it looks like it has been sitting for a while without oil
Raider12
It would nice if you could fill it with oil and pick it up and shake it around some to slosh the oil all over. It could be something as simple as a dry spot just needs lubed up. Maybe try filling it full of oil and letting it sit a day or so. If you did this, I would fill it full with transmission fluid and let sit a couple of days and then try and work by hand. Then drain the fluid out and repalce it with the correct oil.
Denver
Kelly
I've had old engine that sat have sticky valves that kinda squeaked, sprayed PB blaster on the valve stems and turned it a few times and like magic was gone :omg:
zach l
ok ill try it. and is there anything behind the fly wheel that could be doing this? its just a thought
buckeye
:D
zach l
i tried free all on the valve stems didnt help :omg:
Buzz
Have you put oil in it yet? If you haven't anything from the bearings to the wrist pin to the rings could be making that noise. Remove the spark plug and squirt a little oil down the hole.
zach l
i found the problem! one of the magnets on the fly wheel came loose can they be glued back on? if so with what? :omg:
oldandred
Some peolpe glue them back on BUT not me no way
Operator
How about good old reliable JB Weld? :omg:
Randy
