zach l 2 #1 Posted March 29, 2010 i have a k301 and if you turn it over by hand it has a squeak any ideas? Share this post Link to post Share on other sites
rickv1957 77 #2 Posted March 29, 2010 Does engine run OK?,Rick Share this post Link to post Share on other sites
zach l 2 #3 Posted March 29, 2010 i have no idea i wanted to find the problem before i tried to get it running Share this post Link to post Share on other sites
Buzz 502 #4 Posted March 29, 2010 Did you check to see if any of the engine's sheet metal was rubbing on the flywheel or shafts? :omg: Share this post Link to post Share on other sites
zach l 2 #5 Posted March 29, 2010 i took all the sheat metal off of it. it doesn't squeak the whole rotation either im puzzled :omg: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted March 30, 2010 Remove the dipstick and try it. Share this post Link to post Share on other sites
Raider12 13 #7 Posted March 30, 2010 Ok, I gota ask. Is there oil in it? I know this is a simple tast but, sometimes it's the simplest things we can over look. Has been stting for a long while without being run? Or maybe you don't know the history? Denver Share this post Link to post Share on other sites
zach l 2 #8 Posted March 30, 2010 i have no idea on the history of it but the way the inside looks it looks like it has been sitting for a while without oil Share this post Link to post Share on other sites
Raider12 13 #9 Posted March 30, 2010 i have no idea on the history of it but the way the inside looks it looks like it has been sitting for a while without oil It would nice if you could fill it with oil and pick it up and shake it around some to slosh the oil all over. It could be something as simple as a dry spot just needs lubed up. Maybe try filling it full of oil and letting it sit a day or so. If you did this, I would fill it full with transmission fluid and let sit a couple of days and then try and work by hand. Then drain the fluid out and repalce it with the correct oil. Denver Share this post Link to post Share on other sites
Kelly 1,035 #10 Posted March 30, 2010 I've had old engine that sat have sticky valves that kinda squeaked, sprayed PB blaster on the valve stems and turned it a few times and like magic was gone :omg: Share this post Link to post Share on other sites
zach l 2 #11 Posted March 30, 2010 ok ill try it. and is there anything behind the fly wheel that could be doing this? its just a thought Share this post Link to post Share on other sites
buckeye 5 #12 Posted March 30, 2010 I've had old engine that sat have sticky valves that kinda squeaked, sprayed PB blaster on the valve stems and turned it a few times and like magic was gone :D Share this post Link to post Share on other sites
zach l 2 #13 Posted March 30, 2010 i tried free all on the valve stems didnt help :omg: Share this post Link to post Share on other sites
Buzz 502 #14 Posted March 30, 2010 Have you put oil in it yet? If you haven't anything from the bearings to the wrist pin to the rings could be making that noise. Remove the spark plug and squirt a little oil down the hole. Share this post Link to post Share on other sites
zach l 2 #15 Posted March 30, 2010 i found the problem! one of the magnets on the fly wheel came loose can they be glued back on? if so with what? :omg: Share this post Link to post Share on other sites
oldandred 15 #16 Posted March 30, 2010 i found the problem! one of the magnets on the fly wheel came loose can they be glued back on? if so with what? Some peolpe glue them back on BUT not me no way Share this post Link to post Share on other sites
Operator 7 #17 Posted March 31, 2010 How about good old reliable JB Weld? Randy Share this post Link to post Share on other sites
