bdunegan 0 #1 Posted March 29, 2010 off and running with posts! lol does anyone have or know where to get the rear lift cable. just checked toro site and the cable is gold plated! thaught about making one, but dont have anyway to weld or crimp ball end or adjustment rod on. has anyone tried making one from solid roundstock? Share this post Link to post Share on other sites
rickv1957 74 #2 Posted March 29, 2010 I have seen them made with cable and cable clamps,Rick Share this post Link to post Share on other sites
clintonnut 126 #3 Posted March 29, 2010 I have some cables lying around some with threaded ends some with ball ends. I don't know the numbers so would need somebody to take measurements. Thanks Charlie Share this post Link to post Share on other sites
bdunegan 0 #4 Posted March 29, 2010 i will try to get measurements for you today. would be interested in one if long enough! thanks Share this post Link to post Share on other sites
DoctorHfuhruhurr 137 #5 Posted March 29, 2010 I just ordered part# 105542 from mowerpart.com which was $47.70. That was the cheapest I could find. I had other parts I ordered from there also which made the shipping a little more reasonable. I don't currently have the time to make one so I chose to buy instead. Share this post Link to post Share on other sites
DoctorHfuhruhurr 137 #6 Posted March 29, 2010 If you're making one I read in the post below where Rickv1957 said it should measure 25" from eye to eye. http://www.wheelhorseforum.com/index.php?...6&hl=eye+to+eye Share this post Link to post Share on other sites
CasualObserver 3,411 #7 Posted March 29, 2010 There's also good tips about building cables in this old topic. (Found it in a corner in the basement ) http://www.wheelhorseforum.com/index.php?showtopic=1663 It had some nice pictures in it. Maybe if TT reads this and still has those old pics kicking around somewhere we could put them back in. Even without the pictures, good technical reading on cable building. Share this post Link to post Share on other sites
WheelHorse_of_course 99 #8 Posted March 29, 2010 I have built two of these cables, one for my "not-exactly an 854" and one for my 1969 Charger (similar to the C series). For this cable I used cable clamps and a thimble (if you don't know what a thimble is look here: http://www.usrigging.com/thimbles.html ) I do not have any slot-hitch implements, so my experience my only partially apply. The biggest issue is that even when the bottom hole of the lift mechanism is used, the different between all the way up and all the way down is minimal. I am using a Brinly to Slot adapter and have found I HAVE to use the hole that makes it protrude farther out or with implement drags in the UP position OR does not go far enough down int e DOWN position. My second attempt was with the Charger. Based on the previous experience with the 854 I decided I needed to make sure that the the back end of the cable can go as high as possible before it hits the conduit at the top. I found one clevis to use and put that on the front end. On the back end I slightly modified/bent the thimble and put it through the hole in the slot hitch. I also used only a single cable clamp to allow it to move further up in the up position. This worked well except for the problem below: On both tractors I have had problems with the clevis pin breaking at the lift mechanism. On the 854 I assumed it was due to the makeshift and assymetrical way I attached it. (A large washer over the thimble and the pin run through all the way. However on the Charge I broke the pin as well. Both pins were from an assortment I bought a while back (the so-called universal style with multiple holes). I never got back to it in the fall, my next attempts will be a clevis pin from the hardware store that is not too thin (I have been carrying that pin around in my pocket going on 5 months)! Anyway, that has been my experience so far. I still think I am ahead in terms of $s, and suspect that I am close to having working cables! :omg: Share this post Link to post Share on other sites
