Pirate 0 #1 Posted March 28, 2010 After asking and seeing $50 tow ball hitches on ebay, I searched the scrap pile and used a 1/2" thick piece from a bolt on trailer hitch. A few bends with a lot of heat and a big hammer, and I had a hitch. [code Share this post Link to post Share on other sites
Gene_S 93 #2 Posted March 28, 2010 I Like it... Simple and covers both types of towing, ball and pin! :omg: Share this post Link to post Share on other sites
rickv1957 75 #3 Posted March 28, 2010 Looks like your hitch will work fine,dont pull any thing too heavy though as stock drawbar has a limit,Rick Share this post Link to post Share on other sites
Roger from southern Iowa 1 #4 Posted March 28, 2010 Hitch looks good. Like Rick said, the stock draw bar has it's limitations. :omg: Share this post Link to post Share on other sites
Pirate 0 #5 Posted March 28, 2010 Hitch looks good. Like Rick said, the stock draw bar has it's limitations. As I found out, as the orig. hitch bar started to bend. I added an adjustable chain to the setup. Each end is attached to the bracket on top of the transaxel and the middle of the chain is bolted to the top hole in the mount I made. I adjusted it to be tight, when the forward end of the orig. bar makes contact with the bottom of the transaxel. modification #1 Share this post Link to post Share on other sites
Pirate 0 #6 Posted March 31, 2010 Chain addition. I'm now thinking of welding a pad on the front end of the orig. tow bar, to spread out the pressure where it presses on the transaxel housing. Share this post Link to post Share on other sites
Roger from southern Iowa 1 #7 Posted March 31, 2010 Looks lots stronger. The pad would spread the weight over a much larger area. Share this post Link to post Share on other sites
jusjeepn 59 #8 Posted March 31, 2010 Here's an idea: Go to your local junk yard, look for a car with one of those class 1 drawbar (flat stock) type hitches. You should be able to pick one up really cheap because no one wants those. Cut the end off and your left with just a square tube with a flat adapter. Cut a "V" in the square tube so it can be bent back on both ends. Weld the bends. Weld a piece of flat stock on the end, drill a few holes, use the flat stock pieces off your snow plow mount and VIOLA!!!! You have a bolt on hitch that is stronger than your draw bar, clamps around your axle housing and has a slot for interchangeable hitches. I suppose you could get real crafty and put a couple of pivots at the axle mount and just turn it into an extra wide slot hitch that would be 2 to 3 time stronger that the factory hitch. Any how, Nice fab job on the hitch and I wouldn't worry to much about weight on the rear. Common sense should tell you that your 30' yacht is too heavy for that tractor :omg: Share this post Link to post Share on other sites
