Crazywheelhorseman 74 #1 Posted March 28, 2010 I'm looking for any information i can get on this motor. i need to know if i can find plugs for this still and what type of carb should be on it. the reason i asked about plugs is that since it is mil spec the ignition wire screws on to the plug. what do you think charlie? Share this post Link to post Share on other sites
clintonnut 127 #2 Posted March 28, 2010 Some plugs have an end that you can screw off. Does the old plug have any numbers? Are you on my forum?? You can use a Walbro HEW (like hens teeth to find), Carter UT, or a Zenith carb. Some Wisconsin carbs will work. I have a good 90 degree elbow that the carb mounts to if you are interested. Share this post Link to post Share on other sites
Crazywheelhorseman 74 #3 Posted March 28, 2010 I have a few zenith's here that i'll try. what horse power would this motor be rated for? Share this post Link to post Share on other sites
clintonnut 127 #4 Posted March 28, 2010 7-8hp Charlie Share this post Link to post Share on other sites
Rebel13 0 #5 Posted January 9, 2024 I am also working on one of these engines. Model 416-1300-009. I've lost spark on it after replacing the points/plug wire. Any idea what magneto coil part number is for these engines? Share this post Link to post Share on other sites
