MaineDad 87 #1 Posted March 26, 2010 Guys, I have a replacement solid state coil for the 71 Bronco 14 on the way. What's the possibility of switching this back to using points, coil, and condenser? Does anyone have the steps outlined? I did some searching with no luck... Share this post Link to post Share on other sites
clintonnut 127 #2 Posted March 26, 2010 As long as your engine has a plug over the hole for the points push rod it should be a piece of cake. Charlie Share this post Link to post Share on other sites
MaineDad 87 #3 Posted March 26, 2010 The block where the points would go has no cover and the holes are all plugged. So it would seem that this will stay with a solid state coil. Are there other options besides the original solid state coil? Share this post Link to post Share on other sites
rickv1957 77 #4 Posted March 26, 2010 Micah, block should have a small plug that can be knocked out for the points pin and the two threaded holes for the points cover,Rick Share this post Link to post Share on other sites
pfrederi 19,874 #5 Posted March 26, 2010 I would guess that the plunger hole has a welch plug or a cup shaped (think freeze plug) plug in it. The threaded hole above and below it are probably packed solid with dirt. I have a 310 from an electro 12 with the electronic ignition and with some cleaning I found the holes were threaded and there is a plug in the plunger hole. Share this post Link to post Share on other sites
Horse Rancher 0 #6 Posted March 26, 2010 Could this be a newer magnum series block ! the swap can be done with minimal machine work :omg: Share this post Link to post Share on other sites
Sparky-(Admin) 24,623 #7 Posted March 26, 2010 Micah, my neighbor Tony (docwheelhorse) and I did this swap a few years back on a Charger 12. The hole for the points should be there and will just need to be punched out. Obviously you will need a set of points with a cover and gasket but also a coil, condenser and I think a new ignition switch, although I'm not positive about the switch part. I cant seem to remember back that far . We did have some issue with the ignition switch but I'm not sure if it was a bum switch or some bad wiring. But the point is it can be done. Mike.......... Share this post Link to post Share on other sites
clintonnut 127 #8 Posted March 26, 2010 You will need a new switch that delivers power to the coil. Solid state switches don't do this. They use a mag switch. Charlie Share this post Link to post Share on other sites
Sparky-(Admin) 24,623 #9 Posted March 26, 2010 Check out this old thread. The member who bought the device in this thread "tripped off line" and moved on to other forums so we never got to hear how it worked out. Might be another alternative for you Micah . Mike........ http://www.wheelhorseforum.com/index.php?showtopic=5034&hl= Share this post Link to post Share on other sites
WheelHorse_of_course 100 #10 Posted March 26, 2010 Micah My 69 Charger works perfectly with the electronic breakerless ignjition, both on the original and the replacement 69 engine (that was a lucky break). I know you can zap the electronic ignition if you use an arc welder on the frame. I thought there was a mod in the manual to make them more reliable, but I looked through the Kohler books and I can't find anything. If you do some searches I suspect I must have heard it here on Red Square since it does not seem to be in the manuals. Anyway, good luck. :omg: Share this post Link to post Share on other sites
