Countdown To Christmas!
KC9KAS
Lift Lever Adjustment
KC9KAS
While working my 654 with the dethatcher, the lift lever height adjustment knob unscrewed itself and fell off of the tractor, as well as the threaded "L" bolt.
Fortunately, I found both pieces, but I was wondering what can be done to keep this from happening again.
I experienced the same problem while snow plowing this past winter.
Ideas??
Kelly
I have a few with lock nuts installed on top of the knob not as easy to adjust but won't fall apart
KC9KAS
Yeah, I thought of a jam nut, but would have to carry my "save the world" wrench (4" adjustable wrench) all the time.
A lock nut (nylon insert) epoxied to the knob would work, but in time with a lot of use, it will become loose.
C-Series14
On the C-Series, I use the little black plastic cap that goes on the lift lever release button to put over the end of the threaded "L" rod...at least that is what it looks like is on there!!! :omg:
Duff
Mike, according to my parts list, that little plastic thingy is actually made for both purposes!
Duff :omg:
rickv1957
A rubber carb vaccum cap works well also,Rick
buckrancher
you want a rod end cap for 3/8" dia.if you know anyone who works in
a machine shop new end mills are shipped in tubes that use these as
end caps
gwgdog66
This is what I did on mine also. 12 or 10 years ago. Hasn't come off since :omg:
Old Dave
I bought a 3/8" wing nut and put on mine when I bought it in 1978. Easy to adjust and it's till there.
C-Series14
Duff :omg:
No wonder it looks so normal being on there!!! :D
