wheelly
401 suburban
wheelly
looking for fuel tank for 401 suburban. What other models have the same tank in them?
clintonnut
An oval tank will work that is off a 603 and 704. Some tanks might have a different filler neck and the outlet might be in a different place.
Charlie
Kelly
The 603 and 704 have the wrong filler neck and is a diff size tank, not buy much but is smaller, I tried fitting a suburban tank in my 603 and it don't fit, you need a RJ or suburban tank, the tanks that mount to the little Kohlers some not all are very close.
tractorman
how bout a tank off of a 4 horse koler is it the same thing stationary engine it might work there are pretty common
<_<
DMK855
Tractor man, I have one of those and it is quite a bit smaller!!
Wheely, I may have a suburban tank that will work for you. Shoot me a PM!!
Buzz
According to the milicalawn site, the 401, 551, and 701 gas tanks are the same ( part # 1785). If you can find a tank that is the same size you can have the filler neck moved and/or extended if necessary. That's what I had to do to my Bantam.
Kelly
I can tell you a 701 is not the same, and some not all stationary engines have a tank that is close and will work
wheelly
I bought a 401 today and picking it up tomorrow so I'm not sure if the tank straps are even on it. I will learn more tomorrow. I have a tank that sits on top of a k91 I'm hoping it will fit. this is my 3rd purchase in the last month. Just got done with a 653 and an RJ 58.
Thanks for everyone's help. If i could ever get the picture thing figured out i would show my 653 and 58
