Electro12WH
Which One???
Electro12WH
I have a '74 B80 and two decks. One is a 36"RD and a 42"RD. Which deck would you use?
CasualObserver
How often do you mow? I ask because I currently use a 42" deck on an 8HP tractor, but if I let it go to long between mowings I have to take it pretty slow, thick grass bogs down the deck and 8HP is almost not enough to churn through it. If you tend to let things go tall and thick between mowings I'd say you'd be better off with the 36.
markslawnmowerworld
If i were you i would put a plow on,and box up both decks and send them to my house..... B)
rickv1957
I would keep both decks and try them out,Rick
Electro12WH
How about I put the 42 on a C160 and you come and buy it???
sorekiwi
I agree with Jason here.
I have a 36" deck for my B-80 and although I've never tried the 42" on it I think it would be too much for it. Having said that though, the grass I cut is very thick and has a lot of thatch. I need to mow at least once a week during Spring and even the 36 struggles in the thick stuff.
The 36" deck is my best mowing deck though, so I have used it a lot around the house and in the tighter spots. For the other 1 1/2 acres I use the 42 on a 14hp auto. This summer I hope to be using a 48" on a 520.
It is amazing how much quicker it is to finish the mowing with the bigger deck. That extra 6 inches really adds up!
