1961551 2 #1 Posted March 3, 2010 hi, just got home today with a rj 58. ive always wanted an rj. this one is a little rough. i say a little. i like them a little rough, that makes them cheaper . this one was free. and the whole time it was less than one mile from my house. i spotted the top of steering wheel from road yesterday. owner said theres nothing left of it. so its mine now! good and bad news. BAD NEWS... a bag of fertilizer was stored on the hood outside for ? years so hood is shot. i mean gone, gas tank gone. i found part of a strap for the gas tank. steering is froze solid. deck is partially gone. GOOD NEWS... frame is pitted, but good and solid. k91 turns over, and oil is clean. all original k91 with oil bath air cleaner. all pulley covers intact and solid. muffler sheild solid. i pulled shifter out , and trans is clean on the inside! shifts through the gears. fenders are solid. i can get this one going. i just need a hood . im proud of it. it has the original tag on it. it reads RJ-58. serial number-7725 Share this post Link to post Share on other sites
rickv1957 74 #2 Posted March 3, 2010 A diamond in the ruff for free! Rick Share this post Link to post Share on other sites
stevebo-(Moderator) 8,531 #3 Posted March 3, 2010 It is a start. I am sure that you will be able to find a hood. You have your work cut out for you but it all depends on what you are looking to do with it. I would take it apart and either have it sandblasted or get those parts in an etank. Good luck and keep us posted as to what you are going to do B) Share this post Link to post Share on other sites
chazm 413 #4 Posted March 3, 2010 Cool ... everybody loves freebies... Chaz :party: Share this post Link to post Share on other sites
Roger from southern Iowa 1 #5 Posted March 3, 2010 You have a start, more than some of us. A LOT of the "normally gone" stuff is there. I'd say you're on your way. For the investment you have you can spend the time this one will take. I say you did good. B) Share this post Link to post Share on other sites
JimD 3,347 #6 Posted March 3, 2010 well it is rough, but certainly salvageable. Looks like a great project to me. B) Share this post Link to post Share on other sites
MikesRJ 558 #7 Posted March 3, 2010 Man that serial number is quite low too. I wonder about the K-91 though. I would think one with that low a serial number would have a K-90 on it, perhaps replaced in its past? Can you read the K-91's Spec number? I'd be interested in what it says. Great find, good luck with it. :party: Share this post Link to post Share on other sites
evanloock 236 #8 Posted March 3, 2010 The K-91 is correct. The spec on the K-91 should be 31307. The K-90 27107 was only used on the 1st 4000 or so RJ-58's from what I've seen. Most of the RJ-58 literature also quotes a 4hp motor which would be the K-91 or Clinton B-1290. Early RJ-58 ads spec a 3.6 hp engine which would be the K-90 or Clinton 1200 (as also used on the RJ-35). My RJ-58 with the K-90 is serial 3796. Share this post Link to post Share on other sites
Gene_S 93 #9 Posted March 3, 2010 Thats just amazing Jimmy... Very cool find... Now how many more like that are out there to be found??? Share this post Link to post Share on other sites
Kelly 1,033 #10 Posted March 3, 2010 Ruff for sure but most of the hard to find parts are there that is a plus, and FREE is the best part. Share this post Link to post Share on other sites
VinsRJ 723 #11 Posted March 3, 2010 Nice find, with some work you can bring it back. From the looks of the flywheel nut it most likely had a Schancke recoil on it at one time. The manual rope starter must have been a replacement. Share this post Link to post Share on other sites
Lane Ranger 11,395 #12 Posted March 3, 2010 Nice start of a beautiful marriage... B) Share this post Link to post Share on other sites
evanloock 236 #13 Posted March 3, 2010 The Schnacke equipped K-90/K-91 HAVE the backup rope starter installed under the recoil. The one on that engine looks a little bit wider than the original, but it jut may be the angle of the shot. Share this post Link to post Share on other sites
VinsRJ 723 #14 Posted March 3, 2010 The Schnacke equipped K-90/K-91 HAVE the backup rope starter installed under the recoil. Share this post Link to post Share on other sites
Duff 206 #15 Posted March 3, 2010 I've seen guys here bring 'em back from the dead starting with less than you got, so I'm confident it'll be a worthy restoration as your time and resources allow. Congratulations! Duff B) Share this post Link to post Share on other sites
1961551 2 #16 Posted March 4, 2010 i ve got the info off of the engine tag. model K 91 T SERIAL # 382332 SPEC# 31307 A There are provisions for a recoil to bolt onto the blower housing. did it come with one? were they options? mine has no flyweel screen. im thinking it should any help appreciated. jimmy Share this post Link to post Share on other sites
CasualObserver 3,411 #17 Posted March 4, 2010 It would have come with the Schnacke recoil starter that some of the other guys already mentioned. The recoil has the screen, that's why there's not one on the flywheel. The pulley and big flywheel nut are part of this setup. You can find them occasionally. In fact there's one on ebay right now. These pictures (of the one on ebay) show what you're looking for. It will say Schnacke engraved in script just below the center of the face. I should warn you though... they command a pretty hefty price. Lots of people are looking for these. Also commonly found on George garden tractors and Schnacke outboard motors.. but you're not likely to find either of those very cheap either. Share this post Link to post Share on other sites
Suburban 550 28 #18 Posted March 4, 2010 Nice find, Jimmy. It's a little ruff but a very restorable tractor. Good Luck with it. I've seen a lot worse risen' from the grave and you couldn't beat the price. Share this post Link to post Share on other sites
VinsRJ 723 #19 Posted March 4, 2010 i ve got the info off of the engine tag. model Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #20 Posted March 4, 2010 The K-91 is correct. The spec on the K-91 should be 31307. B) Share this post Link to post Share on other sites
1961551 2 #21 Posted March 4, 2010 thanks guys, as far as the recoil situation, its a kohler. if it the k 91 is like all my other kolhers, they start well. so the rope will be fine. i got too many projects right now to start on the rj. the 551 and the 633 are in progress now. my intentions are..... (some may disagree) to find me a rusty hood. free up pivot points. torch and pb blaster. do whatever it takes to get engine mechanically sound. replace rotten left front wheel with one that needs painting. grease contact points. replace only what i have to. no paint. enjoy this baby! jimmy Share this post Link to post Share on other sites
Kelly 1,033 #22 Posted March 4, 2010 You sound like you have a plan, I think it would be cool to leave it like it is, with minor fixes and use it, Make sure you save the ID tag most don't have them after all this time, take a razor blade and slide under it, it looks like it will peel right off. Share this post Link to post Share on other sites
piecrazy4 0 #23 Posted March 4, 2010 B) you have a good start ! Share this post Link to post Share on other sites
wh1257 226 #24 Posted March 5, 2010 nice bud not good codition Share this post Link to post Share on other sites
d180man 5 #25 Posted March 6, 2010 Hi nice find for frree! good luck on it ! :clap: Share this post Link to post Share on other sites
