tommy3horse 3 #1 Posted February 28, 2010 Good evening fellas; I find myself spending more and more time pouring over posts and learning. Thanks for all who contribute! Now then, I have a 72 GT 14 and with the original rebuilt motor, I have also rebuilt the original carb with a Kohler kit. I started the motor and it seems to only run when the choke is full on. I am thinking that I didnt clean the carb well enough, even though I soaked/washed it out with Gumout and blew the passages out and then repeated that process a second time. Anyone out there experience this problem? I have the carb off and wonder what to do with it? Thanks in advance for any assistance, Tom Share this post Link to post Share on other sites
Jim_M 179 #2 Posted February 28, 2010 It sounds like one of the passages is still clogged. Get a can of Chem-Tool and soak the disassembled carb. in it overnight, then blow it all out and give it another try. Share this post Link to post Share on other sites
tommy3horse 3 #3 Posted February 28, 2010 Hi jim, Thanks, just what I had planned! I hope to post pics very soon. I aquired it ('72 GT 14) several years ago with a broken connecting rod. I went thru the motor and used Kohler parts throughout. Shes got a nice original patina, but a new paint job would her wonders. I appreciate your help....I'll keep you posted.... Tom Share this post Link to post Share on other sites
Horse Rancher 0 #4 Posted March 3, 2010 sounds like the float might not be set right also might not be adjusted quite right good luck Share this post Link to post Share on other sites
tommy3horse 3 #5 Posted March 7, 2010 Well, I finally broke-down and got a bucket of carb cleaner with the basket today. I filled the basket with the carb and internals to soak overnight. Is overnight enough? Afterwords, should I spray with gumout again then blow it out? Should I remove the "plug" and clean in there? This is the third attempt........ I sure would like this to work this time. As always, I appreciate all you guys help and reading the threads on repair have started to educate and give me the confidence to tackle this project. Side Note: Also, I removed the steering wheel on the GT14 today. I made-up a split collar to fit under the wheel so as not to damage the plastic. I grabbed the collar(I made it slightly larger that the diameter of the wheel) with a 3 legged puller and it came-off with little effort. Now I can replace the dash. I will include pics of the collar and the tractor soon. Thanks everyone... TOM St. Clair, MO Share this post Link to post Share on other sites
rickv1957 76 #6 Posted March 7, 2010 Tom,overnite is useally enough,I always spray then blowout,also check out carb link on top of engines page as it has some great info,hope it works for you this time,Rick Share this post Link to post Share on other sites
tommy3horse 3 #7 Posted March 7, 2010 Thanks Rick. Also, breaking her down for paint. Gonna sandblast the sheetmetal and use epoxy primer. I powerwashed it today and got everything clean. Even the hydro looks new. B) Share this post Link to post Share on other sites
tommy3horse 3 #8 Posted March 7, 2010 Hello everyone; Well, I pulled the parts out of the soak this morning. I hosed everything off with spray Gumout and blew all parts clean. I carefully reassembled it. I bolted it back on and hooked up all the linkages and pre-set the needles. I hooked-up the battery and turned the key..........and it started, with the choke on and was puffing black smoke!! I slowly closed the choke while adjusting the needles. It runs great and sounds fantastic. Purrs like a kitten!! A long road to a wonderful outcome. Much learned along the way too, thanks to a little help from my friends...here. Tom Share this post Link to post Share on other sites
rickv1957 76 #9 Posted March 7, 2010 Tom,thats great news there! glad you got her going,Rick Share this post Link to post Share on other sites
Jim_M 179 #10 Posted March 9, 2010 All is well that ends well. It may have cost a little more and taken a little more time than you had hoped, but you learned something and you'll know exactly what to do next time. B) Share this post Link to post Share on other sites
Roger from southern Iowa 1 #11 Posted March 9, 2010 Time well spent and lessons well learned. Glad you got it running. Now you can put it to work. :party: Share this post Link to post Share on other sites
