dobeleo 7 #1 Posted February 25, 2010 I am rebuilding my engine, the friction disk came off the clutch plate. Can I glue it back on? what type of adhesive should I use? Should I just buy a new one? Where? I wire-wheeled everything, surfaces are clean to glue back together Thanks again for all your input! Dan Share this post Link to post Share on other sites
rmaynard 16,696 #2 Posted February 25, 2010 Check out the following thread. Bob http://www.wheelhorseforum.com/index.php?...=brake+material Share this post Link to post Share on other sites
rickv1957 77 #3 Posted February 26, 2010 Have glued a couple of plates on with jb weld and worked great,Rick Share this post Link to post Share on other sites
Audioshot 2 #4 Posted February 27, 2010 I didn't know you could do that. Can you buy just the friction stuff and glue it on? Or is this just the case if the original falls off? Share this post Link to post Share on other sites
