brybrychrismer 17 #1 Posted February 23, 2010 can someone help i need a pic of how the deck hooks into the mid tach a matic spot on a C120 and how the manual deck lift hook up goes. thanks in advance thanks Bryan Share this post Link to post Share on other sites
tgranthamfd 29 #2 Posted February 23, 2010 I don't think I have any pictures, but just slide your deck under there with your lift handle in the up position, slide it forward and put your belt on, then slide it back and drop your lift lever, you may have to slide your deck to one side then back to get the lift lever in the front to back slotted hole, then make sure the fork on the deck mount goes centered onto the mid tach amatic rod, kinda make sure everything is in close proximity, and raise the lift lever. should raise and the mid should lock into place. Hope all that made sense. Share this post Link to post Share on other sites
sorekiwi 761 #3 Posted February 23, 2010 Do this backwards! http://www.wheelhorseforum.com/index.php?showtopic=290&hl= Share this post Link to post Share on other sites
Don1977 605 #4 Posted February 23, 2010 Here are a few pictures. Once you get this done just lift the base. It's best to have the belt in place on the deck before you attach the base. Hope this helps. Share this post Link to post Share on other sites
brybrychrismer 17 #5 Posted February 23, 2010 thanks I had the fork pointed down it helps to have pictorial of how to put on and take off the deck. Bryan Share this post Link to post Share on other sites
rickv1957 76 #6 Posted February 24, 2010 Bryan,very simple,arnt they! Rick Share this post Link to post Share on other sites
tgranthamfd 29 #7 Posted February 24, 2010 The first time I took my deck off, I couldn't figure out how to get the mid mount unlocked. My brother usually did it for me. I finally had to make him just let me do it. All a learning process. Share this post Link to post Share on other sites
brybrychrismer 17 #8 Posted February 24, 2010 i agree that its a learning process I guess I got a lot to learn. But thanks to this site if i get to aggravated there are people who can help. SOOOO Thanks Everyone for the help!!!! Bryan Share this post Link to post Share on other sites
