Dale 0 #1 Posted February 22, 2010 who makes cat 0 3pt hitch attachments and where is a good place to buy. looking for a potatoe plow. also which brands should i stay away from thanks dale Share this post Link to post Share on other sites
Rideawaysenior 28 #2 Posted February 22, 2010 Depends on what you are looking for. Some implements can be obtained from Tractor supply, and you will need to change the pin size and invert them for tools such as box blades, rear graders ETC. Just a word of advice, check the weight of your implement before you commit to buy. I have a D160 and found that some attachments I've needed counter weights for in order to keep the front end on the ground. Jack Share this post Link to post Share on other sites
SALTYWRIGHT 861 #4 Posted February 22, 2010 HI....GO TO THE VENDORS LIST HERE ON RED SQUARE . STEVEBO HAS THEM AND HE WILL BE AT THE BIG W/H SHOW IN PA. THEY ARE WELL MADE. RUSS B) Share this post Link to post Share on other sites
Cody 277 #5 Posted February 22, 2010 I have a cat 0 woods RBC60 rear blade and it works great, frontier also makes cat 0 attachments like rear blades, landscape rakes ect. Also i believe northern tool sells some cat 0 attachments Share this post Link to post Share on other sites
Rollerman 290 #6 Posted February 22, 2010 sears The Sears 3PH implements were actually smaller than the cat 0 size & won't fit. HI....GO TO THE VENDORS LIST HERE ON RED SQUARE . STEVEBO HAS THEM AND HE WILL BE AT THE BIG W/H SHOW IN PA. THEY ARE WELL MADE. RUSS Russ you are right Steve does make a nice 3PH, but Dale is inquireing about the implements themselves. Dale it kinda depends on what machine your 3PH is on. Most of the implements sold at the farm stores are considered a small cat 1. The width is correct...you'll have to swap in cat 0 pins & the top link bracket is going to sit a little high. With a little work they will fit, but there going to be heavy. A D series or GT 14 will do okay, but a 3PH on a C series & the tractor may be to light for the implement I have a box scraper & rear blade for my D's that are the small cat 1 size. They work but the front's pretty light on my D 160 single & I doub't I can pull the box scraper with all the rippers down. King Kutter makes a lot of the sub compact or small cat 1 sized implements. http://www.kingkutter.com/ Brinly-Hardly Co. makes some nice cat 0 3PH implements for GT's http://www.brinly.com/ Another option is to build or buy a cat0 draw bar with a top link mount, it looks like a triangle. Then you can put a sleeve or clevis hitch adapter on it & use most any garden tractor implement designed to work in that type of hitch on your 3PH. Share this post Link to post Share on other sites
Dale 0 #7 Posted February 23, 2010 i have a 2418 economy power king Share this post Link to post Share on other sites
Kelly 1,035 #8 Posted February 23, 2010 I have a potato plow but it is a sears 3 point if it will work for you? Share this post Link to post Share on other sites
