Iggy68 28 #1 Posted February 20, 2010 I am going to be looking at a GT14. It has not been running for almost 5 years.What kind of things should I look for with the hydrostat drive to check it out if the tractor isn't running. I wouldn't want to pay too much if it needs a bunch of work. Share this post Link to post Share on other sites
Sparky-(Admin) 24,036 #2 Posted February 20, 2010 Pull the dipstick first and see what the fluid looks like. Its either ATF which is red or 10w-30 motor oil. Make sure it looks clean with no signs of water. If the bottom of the dipstick is rusty it might of had water issues in the past. Then get under the tractor and check for leaks and cracks (or welding marks from past cracks ). Look at the axles where they leave the tranny case for leaks as well as any up/down play which might mean the axle bearings are bad. Good luck. Mike.......... Share this post Link to post Share on other sites
rickv1957 77 #3 Posted February 20, 2010 Mark,another thing to check is the parking brake,pull up handle and see if brake sets and holds you from rocking tractor,Rick Share this post Link to post Share on other sites
bitten 134 #4 Posted February 20, 2010 Check to see if they released the tow valve if they had moved it. As you are looking under the seat it would be on the left side of the tractor. Good Luck Share this post Link to post Share on other sites
Iggy68 28 #5 Posted February 20, 2010 Here is what I am looking at. 1972 model. Share this post Link to post Share on other sites
Don1977 605 #6 Posted February 20, 2010 It needs a new home all sad and neglected, buy it!!! :party: Share this post Link to post Share on other sites
rickv1957 77 #7 Posted February 20, 2010 Very well restorable or workable tractor!!,Rick Share this post Link to post Share on other sites
Iggy68 28 #8 Posted February 20, 2010 They are asking 500.00. I am going to offer 300.00. Is that fair? Comes with the plow. Share this post Link to post Share on other sites
Sparky-(Admin) 24,036 #9 Posted February 20, 2010 They are asking 500.00. I am going to offer 300.00. Is that fair? Comes with the plow. More than fair for tractor with a motor you cant hear run. Just my opinion. Mike......... Share this post Link to post Share on other sites
