Countdown To Christmas!
wheelhorsecravins
r j axel seals
wheelhorsecravins
can anyone trll me where I can get axel seals, I have no manual for part #'s but old seals are two parts held in place bu a collar, thanks mike p s #'s on top of trans case behind the shifter is 3501 and # on raised block right saie of shifter is E26D
N
VinsRJ
Original axel seal which fits in side the axel tube is: CR Services Seal Part # 9815 / HM14
Axel seal which crimps over the axel tube is: SKF Seal Parts # 9835 / HM14 R
In-Put and Brake Shaft seals are: National Seal Part # 471643 or Victor Seal Part # 65140
I'll have some of these seals in stock shortly.
MikesRJ
I don't know which RJ you're working on so here's all three manuals:
RJ-25/35:
http://www.mywheelhorse.com/graphics/file/...vice-Manual.pdf
RJ-58:
http://www.mywheelhorse.com/graphics/file/...M&IPL_RJ-58.pdf
I would suggest you go to a Toro Dealership and buy the seals, or you can buy them direct from the Toro website. The part numbers you need will be in one of the manuals above.
DMK855
Toro axle seals - 83-2840
Toro Input/Brake shaft seal - 83-2830
They are still available from your Toro Dealer!!
