Ken B 3,202 #1 Posted February 16, 2010 I was working on the 518 today sorting thru a few minor issues when another issue popped up. While driving down the road with the snow blade up (manual lift) it will just plop down by itself intermittently. I did some nosing around and I didn't come up with much. The release button seems to be working properly. I'm not too sure if something is broke or not on the lock mechanism. Any idears would be greatly appreciated. I'd really hate for us to get bombed with a huge snow storm in CT. (yeah right) and not be able to use the 518. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted February 16, 2010 Chances are, it will either be the lock rod or the notch in the "quadrant". Remove the left side access panel and have a look around. Note: Sometimes the lock rod spring doesn't exert enough pressure to pull (and hold) the rod completely up into the notch, or the rod itself could be bent down slightly. Share this post Link to post Share on other sites
Ken B 3,202 #3 Posted February 16, 2010 Thanks a bunch TT. I did remove the panel earlier today and nosed around a little. Something tells me its a bad notch in quadrant. I'll have to hunt one down Thanks again, much appreciated. Ken Share this post Link to post Share on other sites
truckin88 104 #4 Posted February 16, 2010 Ken, are you sure the bolt is in the right hole for the piece that connects the plow frame to the lift. On the plow frame there are two holes one is a perfect circle, the other is oblong. this is where a bolt or quick pin goes to connect the plow frame to the metal piece that connects to the lift. I had the same issue, I switched from the circle hole which had the flat metal connecting piece doing / to the oblong one that has the metal piece doing this | ..... This was on my 310. It no longer drops.... Good luck Share this post Link to post Share on other sites
Ken B 3,202 #5 Posted February 16, 2010 I'm pretty sure thats not it because I took the plow right off the tractor and if I bump the armstrong just right it will plop down without touching the release button. I appreciate the input! Share this post Link to post Share on other sites
jdwheelhorse 0 #6 Posted February 18, 2010 Your lift lever is bent outwards. This happened on my B80. Get off the tractor and push the entire lever towards the tractor as hard as you can. Worked for me. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #7 Posted February 18, 2010 Your lift lever is bent outwards. This happened on my B80. Get off the tractor and push the entire lever towards the tractor That doesn't apply to this tractor. They are a totally different design after 1977. Share this post Link to post Share on other sites
nylyon-(Admin) 8,607 #8 Posted February 18, 2010 Ken, I'll check my limited parts bin, I may have that piece for you #41. edit: I just gave a quick look in my totally messy garage, and I'm positive I have it, I just can't find it at the moment. Share this post Link to post Share on other sites
Horse Fanatic 51 #9 Posted February 19, 2010 Another possible problem is, if the lift height adjuster behind the panel is set so it lifts the plow to the highest possible point, it may not allow you to fully get the pin to the notch. Back the adjuster off a few turns (lower the max height) to fix it. Does this make sense? Share this post Link to post Share on other sites
rickv1957 77 #10 Posted February 19, 2010 Ken,quadrant can be built up with a little weld and reshaped also,Rick Share this post Link to post Share on other sites
