DMK855
K181 governor tab??
DMK855
I have a K181 that was missing some external governor pieces. I picked up the parts that I needed and while I was installing them, the whole shaft pulled out. It appears the tab has fallen off. I have not torn into it yet, but plan too real soon.
The question that I have is will I need to tear down the complete engine, or is it something that can be done with minor teardown?? Thanks in advance!!
MikesRJ
sorekiwi
I think I read somewhere that someone managed to get at the governor pieces without removing the crank, but when I tried I couldnt get up there.
I ended up removing the crank, but I did leave the piston up the bore...
TT
I can do the big blocks without removing any internals, but I have never tried to do a 141/161/181 - mainly because I've never seen one with a broken governor shaft tab. B)
Kelly
I did a K181 and had to pull the crank and I think I pulled the cam but it's been awhile, the tab was broke off.
