boatman
lift system
boatman
B) <_<
Hey guys, just had another question on electric lift system. Does
the one end of the actuator go the floor rad same as hydraulic
cylynder? I have never seen one on a tractor. I have a 312 hydro
and hydraulic cyl. goes on the step plate rod behind brake peddlel.
I would appreciate any info or pics of the electric set up.
thanks to all
rickv1957
I have an electric lift,will have to check,Rick
boatman
B)
Thanks rick. I appreciate you checking. This is a prodject I been
wanting to do for along time.
Horse Fanatic
It goes to a bracket which attaches to the frame, It doesn't sit level like the hydraulic cylinders do, they go "uphill" towards the engine. Also, it is wider and they used a different side cover. Also the support under the battery tray has to be trimmed.
You can download an installation manual.
Glenn
boatman
B) suject electric lift rock shaft
Rick I was wondering if you could give me a measurmeant of
how long the bracket on the rock shaft where the actuator mounts is?
would like to know distance from center of rock shaft to hole where
pin goes thru to hold actuator in bracket. I figure I can make a shaft
if I had that measurement.Just wanted to have the right leverage
and distance of travel. THanks
Miles
Glenn, where can you download an installation manual. I too am interested in doing something like this. I was wondering what other model of tractors they used the electric lift on as well.
Daniel B)
Horse Fanatic
Go to the Toro site and down load manual for part #8-4223.
Also, see the photos I just posted.
Dresden Guy
I have tried entering the P/N #8-4223 on the Toro site and it says "no part is found" B)
What is the item(s). Help!! :party:
Thanks
TT
It's not a part number, it's a model number. (and it's actually listed as 84223 ~ without the hyphen)
I know you're trying to find the C-160 version, which means you need to look up 84222.
