boatman 3 #1 Posted February 14, 2010 :party: I just purchased a electric lift actuator for my wheel horse c-125 8 speed tractor. I use this pretty much in the garden and the mold board plow and tiller are pretty heavy. I also have a rear mount grader blade for it. I am wanting to convert this maual lift to the electric lift. I need the part of the rock shaft that replaces manual lever. same as on hydraulic lift. I find out that they are no longer available new anymore. was just wondering if someone had one they wanted to sell? I suppose this part could be made if I had some specs Share this post Link to post Share on other sites
rickv1957 77 #2 Posted February 14, 2010 You will see that rockshaft now and then on ebay,good luck,Rick Share this post Link to post Share on other sites
boatman 3 #3 Posted February 14, 2010 B) Thanks Rick. I just went thru ebay and they haven't had one for awhile. I'll keep on looking tho. They do show a rock shaft for a 520h and it is still available for $ 34.00 . However the notch where cylynder is pinned on is on the back side instead of front side. Does the 520H mount the hydraulic cylynder in a diferent place than say a 312H like mine? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,862 #4 Posted February 14, 2010 You can download a 16 page manual from Toro for the 1991-2004 model. Go to https://lookup3.toro.com/request/request.cfm Use 84225 for a model number and type the word none in the serial # box. Garry Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #5 Posted February 14, 2010 I suppose this part could be made if I had some specs Seek and ye shall find: http://www.wheelhorseforum.com/index.php?...=0entry119119 I'll bet he can get you some dimensions. B) Share this post Link to post Share on other sites
boatman 3 #6 Posted February 14, 2010 B) thanks for info on electric lift. I went to site and down loaded parts list and pictuures & instructions. This helped alot. looks like I need the bracket that bolts to frame and new rock shaft. also new side cover and cltch rod. I can wire it ok and use a mom off mom double pole switch to accomplish reverse polarity to make actuator run either direction. I might be able to fabricate a little on side cover and not have to purchase that. Share this post Link to post Share on other sites
