Countdown To Christmas!
boatman
lift system
boatman
:party: B)
I just purchased a electric lift actuator for my wheel horse
c-125 8 speed tractor. I use this pretty much in the garden and the
mold board plow and tiller are pretty heavy. I also have a rear mount
grader blade for it. I am wanting to convert this maual lift to the
electric lift. I need the part of the rock shaft that replaces manual lever.
same as on hydraulic lift. I find out that they are no longer available
new anymore. was just wondering if someone had one they wanted
to sell? I suppose this part could be made if I had some specs
rickv1957
You will see that rockshaft now and then on ebay,good luck,Rick
boatman
B)
Thanks Rick. I just went thru ebay and they haven't had one for awhile.
I'll keep on looking tho. They do show a rock shaft for a 520h and it is still available
for $ 34.00 . However the notch where cylynder is pinned on is on the back side
instead of front side. Does the 520H mount the hydraulic cylynder in a
diferent place than say a 312H like mine?
gwest_ca
You can download a 16 page manual from Toro for the 1991-2004 model. Go to
https://lookup3.toro.com/request/request.cfm
Use 84225 for a model number and type the word none in the serial # box.
Garry
boatman
B)
thanks for info on electric lift. I went to site and down loaded parts list
and pictuures & instructions. This helped alot. looks like I need the
bracket that bolts to frame and new rock shaft. also new side cover and
cltch rod. I can wire it ok and use a mom off mom double pole switch
to accomplish reverse polarity to make actuator run either direction. I
might be able to fabricate a little on side cover and not have to purchase
that.
