Carlsbarn 0 #1 Posted February 13, 2010 Has anybody ever filled rear tires with foam for weight and run-flat tire? Share this post Link to post Share on other sites
MikesRJ 558 #2 Posted February 13, 2010 Foam isn't going to add a lot of weight to the tires, although it will keep them from going flat. Your better off getting wheel weights, or filling with anti-freeze liquid designed for tire use. Oh, and B) Share this post Link to post Share on other sites
Rollerman 290 #3 Posted February 13, 2010 I've had a few sets of my rear tires filled. Some call it foam but I'm not real sure what it actually is. The tires still remain pliable, won't leak, give a normal ride & are really heavy. I have a set of the 22X 7.50 size common on the 300 series filled that have to weigh close to 100 pounds apeice then a set of 18.50X8's on a Lawn Ranger that weight 55 pounds apeice. I like it better than liquid filling because you don't have sloshing, leaks, or rust damage to the wheel from corosive liquids. The down side is it's semi permanent & you can't remove the filling from the tire, but since it won't ever leak repairs are not needed. If the tire needs replaceing it will need to be cut off so the rim can be reused. Share this post Link to post Share on other sites
d180man 5 #4 Posted February 13, 2010 Foam isn't going to add a lot of weight to the tires, although it will keep them from going flat. Your better off getting wheel weights, or filling with anti-freeze liquid designed for tire use. Oh, and Hi and i dont know about (Foam isn't going to add a lot of weight to the tires) we have a small bobcat that runs 23 tire and they do get heavy when you put it in them just like Rollerman sead ! it has is good and bad ! but we love no more flats ! :party: Share this post Link to post Share on other sites
bitten 134 #5 Posted February 13, 2010 Yes heavy and no more flats, also a lot stiffer meaning that there is not much give which might mean a little less traction B) Share this post Link to post Share on other sites
truckin88 104 #6 Posted February 13, 2010 this si the proper stuff to use (note there are other brands, this is just one): http://www.rimguard.biz/ Share this post Link to post Share on other sites
Audioshot 2 #7 Posted February 13, 2010 The industry slang is called "foam" because it is intended to replace the air pressure and still deflect like a fully inflated tire. It is a liquid polyurethane that cures into a rubbery solid so it acts like a rubber ball. Its intent is to "flat proof" your tires used in extreme chunking conditions like scrap yards and quarries. Tons of people (Waste Mgmt) put it in their front-end loaders because it acts as a ballast. and totally maintenance free. It is VERY heavy. Trust me, your tires will be heavy, you may not need wheel weights. The disadvantage is when your tires finally wear out, you have to cut the tire and rubber fill off the rims with a saw-zall but that's not that hard to do. Arnco Superflex fill is the best stuff out there and it is about $1.75 /lb to inject in. The rear 23x9.50-12" tires on my 310-8 would take about 75 lbs in each tire to do. I filled my snow blower tires. Most earthmover tire companies have Arnco injectors there so you may want to check locally. http://www.arnconet.com/flatproofing.htm Share this post Link to post Share on other sites
Rollerman 290 #8 Posted February 13, 2010 Yes heavy and no more flats, also a lot stiffer meaning that there is not much give which might mean a little less traction This seems to be a popular myth. The "Foam" I had placed in my tires will let the tire deflect or move just as if it were filled with air. I mean 4 to 8 PSI...not 50 either. this si the proper stuff to use (note there are other brands, this is just one): That is one option yes, but rim guard will leak if you puncture the tire. I guess I got wise to the use of foam from work, they (work) had some of the equipment tires done...mostly the fronts on backhoes. It helps as a counter balance & there is no need to call the tire repair to fix a flat. I have seen Rim Guard used too & know it will leak out from a puncture, sliced tire or valve stem be it accidental or vandilism....I also know the "bosses" get grouchy when there is a puddle of Rim Guard on the outside of a tire. Yeah I'm sold on foam....the only negative I can think of is moveing the tires when they are not on the tractor. Share this post Link to post Share on other sites
rickv1957 77 #9 Posted February 13, 2010 Some of the tire foam sets pretty hard giving a harsh ride, Rick Share this post Link to post Share on other sites
Sparky-(Admin) 24,238 #10 Posted February 13, 2010 Does it get stiffer in the cold? What if your foam filled tires are sitting in a cold garage on a concrete floor for a month (between snowfalls say)? Will they develop flat spots? Very interesting topic here ! Mike....... Share this post Link to post Share on other sites
Audioshot 2 #11 Posted February 13, 2010 The Flexfill is pretty spongy. I think it has a 20% deflection (but I'm not 100% sure). You would want that stuff otherwise your teeth will rattle out of your head if they use the renew "hard" fill. I've never heard of it flat spotting. Share this post Link to post Share on other sites
Rollerman 290 #12 Posted February 13, 2010 Some of the tire foam sets pretty hard giving a harsh ride, Rick I would say your seeing something similar to a solid rubber tire then? The Poly or "Foam" is really pliable.....kinda like Stretch Armstrong Does it get stiffer in the cold? What if your foam filled tires are sitting in a cold garage on a concrete floor for a month (between snowfalls say)? Will they develop flat spots? Very interesting topic here Share this post Link to post Share on other sites
Kelly 1,036 #13 Posted February 13, 2010 I bought a Kubuta a few months ago from a guy that got it from work they built trailers and had the tires foam filled, they are still soft like filled with air, I took the valve cap off it looks like reg. foam not sure how heavy they are I never had them off yet, but they are 30x12.5x15's so I'm sure not light, they filled the fronts also because all the screws on the floor, heck I don't think I will need chains there is so many screws in the tires. I also have a pair of 4.80x8 tires that are filled with what looks like black silicone they are about 30lbs each and hard, very little give to them. Share this post Link to post Share on other sites
HorseFixer 2,014 #14 Posted February 13, 2010 Has anybody ever filled rear tires with foam for weight and run-flat tire? Sounds like a pretty solid theory and I am sure it has its place but I dont think it would be very heavy. B) Share this post Link to post Share on other sites
Rollerman 290 #15 Posted February 13, 2010 Duke your welcome to come over & do the bounce test? I'll bounce one of those 22X7.50's at ya & see if you can catch it. B) Share this post Link to post Share on other sites
Kelly 1,036 #16 Posted February 13, 2010 There is a pair of ags 23x 8.5 they say 100lbs each Share this post Link to post Share on other sites
Audioshot 2 #17 Posted February 14, 2010 Quite a few ice rinks have the Zamboni tires filled as well as the larger aircraft tugs. If you know the sizes, I have charts at work that give me the weight it will add to the tire wheel assembly based on the volume of the air chamber. If I remember the front 16x6.50-8" tires will add about 45lbs each, the 12" rears are between 65-75lbs (based on the 8.50/10.50 aspect ratio. Share this post Link to post Share on other sites
Kelly 1,036 #18 Posted February 14, 2010 And that is plus the weight of the tire and wheel correct??? Share this post Link to post Share on other sites
Audioshot 2 #19 Posted February 14, 2010 Yeah, the resin is sold by weight. So the 8" fronts take 45 lbs of the flexfill. It's injected in via the valve stem (with the core removed) and you drill a small hole in the tread on the opposite side to vent the air out. Over time when the tread is worn off, you take a saw-zall with a long wood blade and cut down through the tread and sidewalls on opposite ends of the rim and the tire and fill come off the rims in two pieces. Sort of looks like a doughnut when you break it in half. It's easy for a small tire, but sux for a larger 29.5-25 on a Cat 980. Share this post Link to post Share on other sites
rick 258 #20 Posted February 14, 2010 Okay, I'm sold on the "foam", I need to find somewhere to have it done! Share this post Link to post Share on other sites
Audioshot 2 #21 Posted February 14, 2010 Look up any large truck tire dealers that also do earth mover tires. Ask if they do the Arnco or other Polyurathane fill. There is a place in Plymouth, Ma but it's best to find a local place due to the heavy weight of the final product. Trust me, it almost messes with your head. It seems like they are filled with liquid lead, yet they still bounce. Share this post Link to post Share on other sites
TunaSlayet 89 #22 Posted August 11, 2015 Just got a price for 24x12x12 tire filled at the Sullivan tire commercial location in Plymouth. An impressive 89 lbs per tire at 210 dollars EACH!! Not for nothin, but you can typically buy cast iron for 1 dollar a pound. That is a little rich for my yankee blood. Are there any alternatives to the Arnco line of products? Or am I really going to pay 420 dollars for foam... Share this post Link to post Share on other sites
