6wheeler 669 #1 Posted February 12, 2010 B) I am wondering if anyone knows, was there ever hydraulics on a C-165? I have had this idea to put some on mine. I think I can fabricate a pump mount easy enough, but figuring out where to mount the cylinder might be tougher. Any thoughts? thanks Pat Share this post Link to post Share on other sites
baerpath 517 #2 Posted February 12, 2010 try looking on Toro's sit and use 01-16ke01 for a C165 hydro, or 01-17ke01 for a C175 hydro Share this post Link to post Share on other sites
6wheeler 669 #3 Posted February 12, 2010 Thanks, I looked but all it shows is the parts breakdown. I need to see how a cylinder lays in the frame. I will have to try to find a picture of one, or maybe a tractor for parts. Thanks Pat Share this post Link to post Share on other sites
rickv1957 76 #4 Posted February 13, 2010 A C165 hydro had optional hyd lift,Rick Share this post Link to post Share on other sites
tophatbufflo 2 #5 Posted February 13, 2010 On the older ones they mounted the cylinderfront to the floor board mount and the rear to the rocker shaft. 70 era tractors Share this post Link to post Share on other sites
6wheeler 669 #6 Posted February 13, 2010 Rick, I thought there was something like that. I have never seen one. I have a friend with a c-165 auto but no hyd. either. Would you know how the cylinder mounts. The reason I am asking, I may be able to do this for about $150. If I can make it work, I may be able to get a 3 point setup to work. My parts would be after market, not WH. Before the lynch mob saddles up and heads north, comperable parts , If I could get them, would be alot more. I have a couple of electric lifts I may try also. Thanks for the help Pat Share this post Link to post Share on other sites
