Just getting started 22 #251 Posted November 30, 2023 Been reading about all this painting of this color, that color, aerosol vs mixing. My real question is has anybody thought of using or have you used powder paint? My grandson is getting a powder painting set up for Christmas for the restoration he does of the old Tonka trucks instead of aerosol. I understand a person would need a bid oven or IR light to bake it off with, but it would be durable. Share this post Link to post Share on other sites
Damien Walker 297 #252 Posted November 30, 2023 4 hours ago, Just getting started said: Been reading about all this painting of this color, that color, aerosol vs mixing. My real question is has anybody thought of using or have you used powder paint? My grandson is getting a powder painting set up for Christmas for the restoration he does of the old Tonka trucks instead of aerosol. I understand a person would need a bid oven or IR light to bake it off with, but it would be durable. Hello...I use powder coat for most things now...it is tougher than anything but does tend to chip. It is also potentially rather thick. I use an ordinary domestic oven @180c I think and for approx 10-15mins. The best bit about it is that you can go from a bare part to a finished part very quickly. I use zinc loaded undercoat if a more durable finish is required and I usually blast clean too as this also gives a good key for the paint. Bad clean up is disastrous if the item is going to live outside. If water gets underneath the paint, it will eventually flake off the increasingly rusty metal so make sure it is properly clean and keyed before you start. Cleaning time depends on the size of the item but small brackets can be cleaned, undercoated, top coated and cooled down within an hour....I usually apply the top coat to the hot undercoated item (hot flocking) as this helps reduces the high voltage shadowing effects that can stop the paint getting into corners. Share this post Link to post Share on other sites
PetesPonies1 119 #253 Posted December 1, 2023 If you use a quality urethane clear, your painted items will be very durable. I paint, I have also done some powder coating. I prefer top paint. Share this post Link to post Share on other sites
oliver2-44 11,749 #254 Posted December 1, 2023 @PetesPonies1 do you know if it works to put a urethane clear top cot over a non urethane base. Such as over single stage acrylic or even Rustoleum oil base enamel with hardener Share this post Link to post Share on other sites
PetesPonies1 119 #255 Posted December 1, 2023 43 minutes ago, oliver2-44 said: @PetesPonies1 do you know if it works to put a urethane clear top cot over a non urethane base. Such as over single stage acrylic or even Rustoleum oil base enamel with hardener So . . by the book . .definitely a no-no. Have I cheated a few times and seen decent results? Yes, sometimes. But when trying something new, you have to be ready for failure. So .. if the paint has a hardener in it and you let it cure, then your chances are pretty good. You will have to scuff though before the clear. Spraying it wet -on-wet as you would for BC/CC . .then it depends. and I believe it has a lot to do with thickness. I have sprayed some tractor wheels with "tractor" paint, then cleared. Sometimes it worked out well and other times the final finish was not as smooth as it was when first sprayed. So it reacted some with the "base" paint. BC is very, very close to lacquer in it's make-up. Very thin, and the vehicle comes out very fast. That way it is ready to be cleared in a relatively short time, . .15 minutes to an hour, or the next day, etc. But enamel is slow to cure, has a lot of vehicle in it to come out and that is the major reason for problems when you spray a clear over it that will cure in 5 minutes, 30 minutes or a few hours. You are trapping chemicals that need to come out. Some spray can tractor paint . .let it cure over night,warm days . . then hit it with a coat of clear and it might work out ( I have had it work ). BUT . .definitely not the way it is supposed to be used 1 Share this post Link to post Share on other sites
Damien Walker 297 #256 Posted December 1, 2023 20 hours ago, PetesPonies1 said: If you use a quality urethane clear, your painted items will be very durable. I paint, I have also done some powder coating. I prefer top paint. If you want a show quality finish, then I would agree. Carefully applied multiple coats of 2 pack paint will give you a very durable, uv resistant and beautiful result.....but it takes a lot of time and effort to achieve this. I have to admit to only requiring a durable finish suitable for a working machine, in which case, powder coat wins hands down if you have an oven big enough! I get the big stuff done professionally and the finish is better than anything I can achieve with wet paint. The other disadvantage about powder is the selection of colours that are available...wet paint can be mixed to your specification as can powder, but a batch of bespoke powder is VERY expensive. I'm in the UK so Toro Red (Pantone 186c) is not available as we use RAL and BS colours. I use small surplus quantities of powder (probably excess stock) off ebay which makes powder coating very affordable, but you have to accept the colours that are available. For Wheelhorse parts, I use British Post Office Red which looks OK in daylight but in reality is a little light/orange compared to Pantone 186c. Warning: I found a cross reference to RAL3027 but (assuming my coating company got it right) it turned out rather pink. I have nothing against the LGBT community but this was going a bit too far! Share this post Link to post Share on other sites
Kevin Bowley 140 #257 Posted February 20, 2025 (edited) I used Rustoleum 2x grey primer and Rustoleum IH Red implement paint. I am happy with it. Before restoring, and below is after. It did take a couple of months for the paint to get really hard so I couldn't dig into it with my fingernail. Now it is extremely hard shelled. The picture below is the first time using it and getting all dusty. Edited February 20, 2025 by Kevin Bowley 7 Share this post Link to post Share on other sites
jackhammer 553 #258 Posted February 20, 2025 Great looking tractor and paints worked out well for you 1 Share this post Link to post Share on other sites
kpinnc 18,960 #259 Posted February 21, 2025 16 hours ago, Kevin Bowley said: I used Rustoleum 2x grey primer and Rustoleum IH Red implement paint. I am happy with it. I have used that before as well with good results. As already said, it's not as fast drying as regular rattle can, but it's got higher gloss and seems to be reasonably durable after fully curing. 1 1 Share this post Link to post Share on other sites
Kevin Bowley 140 #260 Posted February 21, 2025 (edited) That was a "field find" through word of mouth. The seller said it had been setting for three or four years because he broke the spindle when he hit a stump and bought a new Simplicity Coquest. It came with a barely used plow, a solid 48" deck (save a broken spindle), original rear tires and wheels with OEM wheel weights, chains, and a grader blade...no way I could see getting hurt even if the machine was junk. He did drain the gas and ran the carb dry when he parked it. Well, I'll be. I got everything home and, without much hope, dragged it into the garage, hooked up the jump pack, poured a bit of gas into the carb, and it fired right up. Put some in the tank, and it ran like a clock (other than about 100 acorns flying out). All the gauges worked fine, as did the idiot lights. A project was born! I purchased the cool decal kit from RedoYourHorse. I want to add that the OEM Wheel Horse paint for the newer tractors looked like it had a better/smoother mirror-like finish with very high gloss, but the spray head was a horrible haphazard and spatteres pattern, where the Rustoleum sprayed with an easy to control flat vertical pattern just like my LVP and was so close to the Toro I chose that. Very happy once it finished laying out for a couple weeks. Of course the prep was a PITA, requiring puddy in some areas to hide pitting as well as wet sanding the primer with 800, but as we all know, it is the most important part of a nice finish. Edited February 21, 2025 by Kevin Bowley 2 Share this post Link to post Share on other sites
Red Stallion 231 #261 Posted February 24, 2025 On 2/20/2025 at 10:09 PM, Kevin Bowley said: I used Rustoleum 2x grey primer and Rustoleum IH Red implement paint. I am happy with it. Before restoring, and below is after. It did take a couple of months for the paint to get really hard so I couldn't dig into it with my fingernail. Now it is extremely hard shelled. The picture below is the first time using it and getting all dusty. I'm going through the same process at the moment. Do you put a clear coat over the paint, or just leave it painted only? Share this post Link to post Share on other sites
Kevin Bowley 140 #262 Posted February 25, 2025 (edited) On 2/24/2025 at 5:03 AM, Red Stallion said: I'm going through the same process at the moment. Do you put a clear coat over the paint, or just leave it painted only? No clear, 3 coats of Rustoleum 2X coverage primer, wet sanded with 1200 with a block by hand (use 3M sandpaper; it lasts forever), and three coats of Rustoleum IH red implement paint laid on progressively thicker with each. I don't have a paint booth to bake it, so I let it set under my Modine heater for a week or so but could still push my fingernail into it. It was about a month before I took it out and got it dirty. It took three to get extremely hard. I didn't want to use my VLP as it's a PITA, and I can get a great finish with a good-quality rattle can with proper prep. She shines like a mirror. I also use these handles for good control. Be sure to use a respirator! Edited February 25, 2025 by Kevin Bowley Share this post Link to post Share on other sites
Red Stallion 231 #263 Posted February 27, 2025 On 2/25/2025 at 11:24 PM, Kevin Bowley said: No clear, 3 coats of Rustoleum 2X coverage primer, wet sanded with 1200 with a block by hand (use 3M sandpaper; it lasts forever), and three coats of Rustoleum IH red implement paint laid on progressively thicker with each. I don't have a paint booth to bake it, so I let it set under my Modine heater for a week or so but could still push my fingernail into it. It was about a month before I took it out and got it dirty. It took three to get extremely hard. I didn't want to use my VLP as it's a PITA, and I can get a great finish with a good-quality rattle can with proper prep. She shines like a mirror. I also use these handles for good control. Be sure to use a respirator! That's some serious dedication and skill! I dont think I am in that camp as I just want to tidy it up. So using a grinder scotch bright wheel to strip the paint and rust off. A few coats on primer, then two coats of colour. Ive been leaving the bits in the sun for a few days to a week, then putting two coats of clear. Yours is very pretty, while mine is more salt of the earth type! Lots of character! Share this post Link to post Share on other sites
Red Stallion 231 #264 Posted March 12, 2025 PS did anyone ever come up with a definitive black for the bonnet detail? I might just see if there is a Rustoleum black gloss Share this post Link to post Share on other sites
kpinnc 18,960 #265 Posted March 12, 2025 8 hours ago, Red Stallion said: Rustoleum black gloss I always thought a satin black looked better. All the small grooves are difficult to evenly clean up, and a satin finish will help hide imperfections. Gloss black shows everything. 3 Share this post Link to post Share on other sites
Red Stallion 231 #267 Posted December 27, 2025 I ended up forgetting that I had a Rustoleum black, and just used a Dulux Black and then clear coat. Now that all the painting it done, I'm not super happy with the Rustoleum and if I had my time again I wouldn't use it. The bonnet and seat pan had been sitting and curing for months and its still soft as, and I can scratch it off with my nail as its barely stuck to the primer. The cheaper Dulux paints stuck like poop to a blanket and that would cure easily within 24hrs. So in a couple of years I'll probably strip it off again back to primer and recoat it. On top of all of that, Sunrise red has been discontinued! Share this post Link to post Share on other sites
Easton Rich 1,260 #268 Posted February 22 What am I doing wrong? I've wet sanded and cleaned this surface as much as I can. I dont understand? I used Rustoleum IH Red. Share this post Link to post Share on other sites
oliver2-44 11,749 #269 Posted February 22 30 minutes ago, Easton Rich said: What am I doing wrong? I've wet sanded and cleaned this surface as much as I can. I dont understand? I used Rustoleum IH Red. Maybe silicone contamination on the base. It can bleed through even with sanding. Share this post Link to post Share on other sites
Easton Rich 1,260 #270 Posted February 22 Yeah. Tomorrow I'll try to remedy that Share this post Link to post Share on other sites
702854boy 1,149 #271 Posted May 5 This is Krylon IH red with the Rustoleum gray sandable filler primer Share this post Link to post Share on other sites
Sparky-(Admin) 26,358 #272 Posted May 19 This was a perfect color/sheen for the black part of a Black Hood tractor. 1 2 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #273 Posted May 19 (edited) I use a mix of the ACE or Rustoleum Implement IH red and semi gloss black for the front of a 3,4.or 500 series or just IH red for the C-141 I have. I use a mix of aerosol or, in the case of the C-141, I painted it with a spray gun. I’ve had no issues durability wise yet. I have no experience with powder coating I can see the advantages like the greater durability etc… Edited May 19 by MainelyWheelhorse Share this post Link to post Share on other sites
Blaine 276 #274 Posted June 9 I painted my 401 with Krylon cherry red 28 years ago and found it to be a very close match, but slightly darker than Rustoleum cherry red. And if it’s stored outside, it will fade just like any other red. Share this post Link to post Share on other sites
WildHorses 443 #275 Posted August 17 On 3/12/2025 at 4:12 AM, Red Stallion said: PS did anyone ever come up with a definitive black for the bonnet detail? I might just see if there is a Rust-oleum black gloss The best paint I've found is Rust-oleum Satin Black, you can't tell it from the Factory finish. This tractor has all OEM paint but the front black I had to redo because of several large scratches. 2 Share this post Link to post Share on other sites
