Countdown To Christmas!
rustynut
not sure what this is
rustynut
i think its like a 1968 or so raider 8 but i got it fer free and theres no tags on it no stickers but ther is a motor identifictation tag on it. it has a kohler belt start engine i havent had time to clean up the tag to find out what it is though so i thought i would see what you guys thought it was. thankks.
http://s816.photobucket.com/albums/zz82/ru...mview=slideshow
sory i sont know how to post the pictures
rickv1957
Not a raider 8 for sure maybe a 857,Rick
Sparky
Dont know what it is but for free you cant go wrong!
Mike........
TT
Forgive me for being so blunt, but if you had time to take pictures, upload them, and then put a post on the forum, you had time to clean off the tag and get the numbers.
Remember......... "He helps those who help themselves."
rustynut
well i was kinda bussy as you could see i took them out side and then i went to read the sticker on the motor and there was tape over it so i pealed the tape off and the sticky stuff off the tape was all over the tag so i cant read anything on it so i got to get rubbing alchohol and try to just take the sticky stuff off instead of the paint off the tag so im soorry i dont have all the time in the world
whfan74
I wish I could help you out...........don't be discouraged, that is a great find! B)
rustynut
thks rick now that you say that it makes more sense thank you. I dont know why i thought it was a raider
TT
So why don't you look under the dash for the tractor tag?
If I'm seeing things correctly, it might just have "T-1046" stamped in it.
By the way.... you're only 15 years old, right? You have a lot more time than you think.
rustynut
i have looked under the dash and everywhere on the frame and i didnt have time today my dad had me plowin the whole day after i got done usein my wheel horse i had to use the bob cat fer 15 other ppl we have to plow out cause they pay us to
whfan74
Time or no time, 15 or 75, let's help this kid out.
TT
I did.
rustynut
thank you whfan umm i think i sent you a message if you the same person I dont know but are you the one with the 857 picturre on here in the photo gallery
whfan74
I don't have an 857 but a 1277.........which it does look like that quite a bit. I am not an expert on these machines but I would have to lean towards what has already been stated. When you get a chance to find the id tag, feel free to post it and we will go from there. Will be tough to see as it sits right under the dash in front of your shifter.
Good luck!
rustynut
the only tag is on the motor ive looked fer 10 min but if you could possibly post a picture on here of a few diff angles i would compare thank you alot
TT
Here's a 1056:
The 1046 is basically the same tractor except that the engine ("leftover" small oil pan K-241 from the 1965 models) was mounted on a riser plate.
Here's yours:
rustynut
alright thanks im not shure if that is the same or not waht do you think
rustynut
alright everyone i found out what she is shes a 1056 so if any yall had pics of one go ahead and post them on here thanks everyone
Sparky
I think TT just identified your tractor as a 1046 and not a 1056. The 1056 has its motor bolted to the frame and the 1046 has its motor bolted to a plate on the frame like yours.
His knowledge about these tractors and the little differences between years is incredible.
Mike........
rustynut
yaa i take that back tt is more than likely right it prob is a 1046 weel have to ssee
Kelly
Did you check the ID tag under the dash?? that will clear it up.
wheel horse 1045
a 1046 would be a better find but either way free is good in my oppinion
Suburban 550
How the administrators put up with this is beyond me. B) Instead of sarcastically trying to make a fool out of someone you should try to help them out.
JimD
ya, look like some want to revert back to their old ways again <_
Sparky
Did you guys read the whole thread? I will admit that TT's first comment seemed a bit crude, but he was trying to get Rustynut to do a bit of investigating on his own. Maybe give us all the info he could find before just giving up and asking.
In the end TT was the only member here who could positively ID the tractor and back it up with facts and pictures which he did after Rustynut did some checking for any available tags.
As a Moderator/Admin I see no issues here.
Sorry if you see it different.
Mike.......
Confused99
Mike.......
edit - Nevermind
