dandan111 66 #1 Posted February 10, 2010 I have been bending wire off and on 3 different times now for the governor. My carb only has 1 hole for the throttle /governor hook up. If I run the rod from the governor to the throttle hole on carb, then run my spring to the governor would this work? This is not like the other set ups I have seen. Bending wire for this thing is a pain,it also has a little nub on top of the carb just below the throttle hole that is driving be crazy. Do any of you guys have a carb like this? Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted February 11, 2010 These are about the best pictures I have of the Tecumseh linkage: These pictures are on a 502, but the H60 on my Lawn Ranger was the same. I dont have a 654 to compare it to, but I assume it was the same as these. You can actually buy a tool for bending the wire. I think its called a "z bender". I just use a piece of steel 3/16 thick, with a hole drilled in it to suit the wire. Poke the wire through it, twist the piece of steel 90 degrees and then on to the next bend. You have to be careful which side of the bend to have the steel on, if you get the piece of steel on the wrong side of the bend, you cant get it off again! B) Share this post Link to post Share on other sites
Michael Bullington 5 #3 Posted February 11, 2010 my 654 setup Share this post Link to post Share on other sites
dandan111 66 #4 Posted February 11, 2010 michael, That is the set up I have,I only have one hole for the throttle on the carb. It looks like you have more. Share this post Link to post Share on other sites
jimt1971 237 #5 Posted February 11, 2010 Hello, Hobby shops sell a pair of Z bend pliers for making the ends of the cables. Thanks, Jim Share this post Link to post Share on other sites
formariz 12,354 #6 Posted February 11, 2010 Check out the one on my 653. It seems to be the same and it has never been touched. http://www.wheelhorseforum.com/index.php?showtopic=8585 Share this post Link to post Share on other sites
dandan111 66 #7 Posted February 11, 2010 Cas, That is the carb that is giving me problems. I do not see a spring in that set up? Did I miss it? thanks Share this post Link to post Share on other sites
formariz 12,354 #8 Posted February 11, 2010 Let me check the tractor and take a better photo. I will post it in a while. Share this post Link to post Share on other sites
Michael Bullington 5 #9 Posted February 12, 2010 Yes I have about 3 holes in the bracket on the carb...the spring is in there just look real close you can see it, but it blends in so its hard to see... Guys any tractors older than 1964 have a completely different setup Heres a better pic Wow i didnt realize how dirty and scratched this has gotten! ..guess thats whats happens when you run the heck out it :party: Share this post Link to post Share on other sites
dandan111 66 #10 Posted February 12, 2010 That looks nice to me,mine is getting a patch job for now. I think my carb is a older style and I may be missing some stuff to make it right. The way yours is set up is what I had in mind. I will use what I have for now until I get it running,still not sure if the motor is a good one. Share this post Link to post Share on other sites
sorekiwi 761 #11 Posted February 12, 2010 Cas, That is the carb that is giving me problems. I do not see a spring in that set up? Did I miss it? thanks Cas's set-up is the same as the one I posted. TYou can see the bottom of the spring in the top left of this picture: But it looks like what you want is the setup from Michael... BTW There is only one hole in the carb linkage on my carbs too. Share this post Link to post Share on other sites
formariz 12,354 #12 Posted February 12, 2010 Here are more detailed photos. I hope it will help. Share this post Link to post Share on other sites
dandan111 66 #13 Posted February 12, 2010 That does help, thanks. Mine is missing stuff,the guys that bought these tractors new would cry if they seen the hack job done over the years. I think it will work the way I put it. (not pretty) Share this post Link to post Share on other sites
