btrrg1969 11 #1 Posted February 10, 2010 The wheel horse manual states that the dial a height control is used to hold an attachment (other than a mower) at the disired height above the ground.Turn the knob all the way to the left for mower opperation . If I am reading that right , is the deck gauge wheels all that is needed for the mower height? Thanks brandon Share this post Link to post Share on other sites
Sparky-(Admin) 23,831 #2 Posted February 10, 2010 Thats correct. Mike....... Share this post Link to post Share on other sites
rickv1957 76 #3 Posted February 10, 2010 Hello and Rick B) Share this post Link to post Share on other sites
Duff 206 #4 Posted February 10, 2010 The wheel horse manual states that the dail a height control is used to hold an attachment (other than a mower) at the disired height above the ground.Turn the knob all the way to the left for mower opperation . If I am reading that right , is the deck gauge wheels all that is needed for the mower height? Thanks brandon First, ! Glad to have you among us! Is your tractor a 300 or 400 series (and I think this may apply to C-series as well)machine? If so, the dial-a-height feature is a threaded "L" rod that goes down inside the dash tower and engages the lift mechanism. When they say to "turn the knob all the way to the left", I would be a little careful - it is possible to turn the knob completely off the rod and then it may drop down inside the machine or out onto the ground depending on the condition and age. I would turn it left (counterclockwise) several turns and then let your mower down. If the mower goes all the way down, you've turned far enough. If not, spin it a couple more turns. Duff B) Share this post Link to post Share on other sites
bitten 134 #5 Posted February 10, 2010 I use mine for the tiller and front blade. Share this post Link to post Share on other sites
nylyon-(Admin) 8,381 #6 Posted February 10, 2010 I have used it maybe once or twice with the front blade. I don't have a tiller and don't have much use for dial a height control. Share this post Link to post Share on other sites
6wheeler 670 #7 Posted February 10, 2010 ok, as long as we are on the subject, when I lift my mower on my c-165 it won't hold it up, and, I can't see why. any Ideas? Pat Share this post Link to post Share on other sites
rickv1957 76 #8 Posted February 11, 2010 If handle is not locking in,maybe needs adjustment or some part is damaged,Rick Share this post Link to post Share on other sites
Duff 206 #9 Posted February 11, 2010 ok, as long as we are on the subject, when I lift my mower on my c-165 it won't hold it up, and, I can't see why. any Ideas? Pat Pat, does the spring that tensions the plunger rod that pushes the release mechanism down inside the lift handle still have tension? (Am I making sense here?)? If that spring is broken or weak, it may not be allowing the lift thingy to engage in the "up" position. Go to https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro. Enter 01-16K801 into the box and hit enter. Click on "View Assembly Drawings" Click on "Lift linkages". Part #4 is the spring. It allows part #2 to lock into the plate, part #41. It's also possible, although unlikely, that the groove in that plate could be worn. Another possibility is the deck lift linkage may be set too high so the deck won;t come all the way up to a locking position. I don't know enough about decks to advise you how to correct this if that's the case, but someone else here will for sure. Hope this gives you some ideas? Duff :party: 1 Share this post Link to post Share on other sites
dcrage 631 #10 Posted February 11, 2010 Brandon I have a 310-8 with a 42 inch deck and 42 inch plow -- I use the "dial a height control" to hold both of these attachments to desired levels above the ground -- When mowing it is NOT needed if you are OK with the cut height using the deck wheels -- I spend a lot of time cutting a yard that only gets mowed 1 time a month -- The lower cutting height using the deck wheel overloads the belt turning the blades when mowing a really tall, thick "yard" -- The extra inch or two lift from the "dial a height control" makes this a managable cut -- I use it on my snow blade because I have a gravel drive and don't want to scrape gravel with the snow Dave Imperial, MO Share this post Link to post Share on other sites
6wheeler 670 #11 Posted February 12, 2010 Thanks for the tip Duff, I tried the thumbplunger? I can't move it very much and it doesn't seem to have any spring pressure. So, I'll take it off and see if I can loosen it up. Pat Share this post Link to post Share on other sites
bitten 134 #12 Posted February 13, 2010 I also use it for a single bottom plow. Share this post Link to post Share on other sites
hotrodmerc 1 #13 Posted February 13, 2010 I use mine for the blade when pushing a gravel driveway. Share this post Link to post Share on other sites
Horse Digger 52 #14 Posted February 1, 2017 My C-120 is lacking the some details on the "dial a height", anyone want to post a picture, perhaps I can fabricate the missing parts myself? Share this post Link to post Share on other sites
obone 142 #15 Posted February 4, 2017 I had to grease mine. When in the up position it would not fully lock. A little bit of white lithium fixed it. Share this post Link to post Share on other sites
Tankman 3,523 #16 Posted February 5, 2017 17 hours ago, obone said: I had to grease mine. When in the up position it would not fully lock. A little bit of white lithium fixed it. I also, from time, shoot a little PB Blaster down the "thumb button" clearance hole. Thinking, "The blaster'll lubricate the spring". 1 Share this post Link to post Share on other sites
ohiofarmer 3,383 #17 Posted February 5, 2017 On 2/11/2010 at 11:51 AM, Duff said: Pat, does the spring that tensions the plunger rod that pushes the release mechanism down inside the lift handle still have tension? (Am I making sense here?)? If that spring is broken or weak, it may not be allowing the lift thingy to engage in the "up" position. Go to https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro. Enter 01-16K801 into the box and hit enter. Click on "View Assembly Drawings" Click on "Lift linkages". Part #4 is the spring. It allows part #2 to lock into the plate, part #41. It's also possible, although unlikely, that the groove in that plate could be worn. Another possibility is the deck lift linkage may be set too high so the deck won;t come all the way up to a locking position. I don't know enough about decks to advise you how to correct this if that's the case, but someone else here will for sure. Hope this gives you some ideas? Duff Wow. That website is like gold. Now all we need to know is how you come up with the code numbers [like 01-16K801] to get to those amazing parts drawings... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,765 #18 Posted February 5, 2017 2 hours ago, ohiofarmer said: Wow. That website is like gold. Now all we need to know is how you come up with the code numbers [like 01-16K801] to get to those amazing parts drawings... This will help for that type of model number Garry 1 Share this post Link to post Share on other sites
