Countdown To Christmas!
xring1
417-A .....Help!!
xring1
Ok figured I needed to start a new thread for this and other stuff I might run into.
Kohler KT17QS series II.........
No spark.......It had weak intermittent spark when I went to get it and I figured it was the weak battery but with a good battery I am seeing no spark now.
Ideas ???? B)
IthacaJeff
Xring,
Fuses and ground wires, fuses and ground wires. Check 'em all. Don't just check
that the fuses are blown, but check how they seat in the fuse holders. It took
me about a year to finally find that it was poor connections in a fuse holder
that prevented ignition starting. I spent a year hot-wiring the starter to get
my Kohler M10 started.
Jeff in Ithaca
xring1
I had another idea.... I do not have a manual for this tractor but are there any safety switches that would shut off spark?
xring1
Xring,
Jeff in Ithaca
There are fuses that affect spark?? The engine turns over fine.
xring1
Is there an online engine manual for this thing?
Where are the points and what should they be set at?
xring1
Yes enter your info in here
https://lookup3.toro.com/request/request.cfm
Jason
Hi Jason
I tried both KT17QS and 417-A and got no results found
xring1
Jason
Hi Jason
found manual
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2043_a.pdf
pfrederi
There are safety switches....
First check for voltage at the coil with the key turned on and the PTO fully disengaged. No voltage = ignition switch, safety switch/wiring issue
Voltage but no spark check the points under cover on top of engine towards front starting setting would be .020...but check for corrosion first....
jtmoyer
i seamed to have a short in my 417. i ran a lead from the pos post of the battery to the pos post of the coil. just what the doc ordered. clip the wire on the battery when i want to use it and take it off when i am finished using it. don't know what the prob was but it fixed its self over time. my 417 sat for 12 years outside before i got it.
xring1
B) Ok then..... I am only 1/2 a mechanic but got it running. Found the points, cleaned and checked gap. Had to nurse it along for awhile dribbling gas into the carb but eventually it ran by itself.
Now it does not like to stay at an idle.... it will idle for a bit then surge up and then come back down....Any ideas here?
While It was running it is charging ok and I checked the hoist ram and it is functioning. An oil gauge would have been a nice thing to have. I can't check the drive till I get a spindle on.
The forward/reverse lever seems stuck on place. anything I need to know about it or do I just go exploring and see if it is hung up from sitting?
The screws in the top of the fuel pump were REALLY loose and it was leaking gas pretty bad. Surprised the previous owner did not catch it on fire.
rickv1957
Sounds like a good carb cleaning is in order!,Rick
Confused99
Glad to hear you got it fired up. Did you find a spindle yet?
Jason
xring1
Jason
Did a quick check on Ebay last night and no spindle.
If all else fails I will rob one off the c-125 to be able to check and see if the transmission works. Guess I will pull the carb off tomorrow and clean it to see if I can get it to stay at an idle
Confused99
Jason
Napa has rebuild kits priced reasonably if you need one. Make sure you use some compressed air too.
Jason
xring1
Jason
Jason
what should i use to clean it? Some carb cleaner
Confused99
Jason
Jason
Yes, use carb cleaner, very fine piece of wire, and compressed air. Post here if you have trouble.
Jason
