ametsman 0 #1 Posted February 7, 2010 I have a Model 6-2211 formerly ST-326 snowblower that was bought in 1966 or there abouts. I am in need of part# 20 which is a 2176 sprocket. Do you know where I can purchase one of these or what I can replace it with? Thanks, my first post on here so be gentle! Share this post Link to post Share on other sites
rickv1957 77 #2 Posted February 7, 2010 Hello and ,will check on #2176,Rick Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #3 Posted February 7, 2010 B) How many teeth are on this sprocket? Share this post Link to post Share on other sites
can whlvr 994 #4 Posted February 8, 2010 without goin out in minus 23 i think i remember 15 teeth on that sprocket,i got one at a bearing shop,but tsc,farm supplie stores and industrial supplies stores are a good place to start. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #5 Posted February 8, 2010 I've replaced a few but can't remember the tooth count on the different throwers. (I don't have one of the ST models here right now either) Martin is an excellent source for these pieces and sometimes they can be found on eBay from surplus companies. Share this post Link to post Share on other sites
rickv1957 77 #6 Posted February 8, 2010 I have several new 15 tooth sprockets,Rick Share this post Link to post Share on other sites
ametsman 0 #7 Posted February 8, 2010 Will check on the teeth tomorrow. Have been gone watching the Superbowl. Thanks for all the replies. Share this post Link to post Share on other sites
ametsman 0 #8 Posted February 8, 2010 Counted them this morning and came up with 17, does that sound right? Share this post Link to post Share on other sites
ametsman 0 #9 Posted February 11, 2010 I ordered a new sprocket. Now I need to figure out how to get the old one off and new one on. Anybody have a clue how I get at the sprocket? Share this post Link to post Share on other sites
can whlvr 994 #10 Posted February 12, 2010 u have to pull the shaft out,i had to take off the pulley,then remove the pins in the end of the shaft that keeps it from moving side to side,then take off the bearing plate bolts and it should come out,i had to cut mine off with an angle grinder and then replace,u may not have to take the pulley off,it might slide through to the right,i had to replace the shaft so i had to take it off,its been a while since i did it but i hope this helps, Share this post Link to post Share on other sites
ametsman 0 #11 Posted February 12, 2010 Thanks can, will give it a try this weekend. Share this post Link to post Share on other sites
