420lse 18 #1 Posted February 6, 2010 I was talking with Tony (Doc) many moons ago and was explaining how my 655 was killing batteries. He said that without a doubt it was faulty diodes. Seeing Cas's thread on his H 60 charging problems got me feeling like I should finally get around to fixing my own stuff. Gotta stop procrastinating. Anyway, I went to rshack and picked up some diodes, $1.65 for 2 and went to work, even though I felt like procrastinating I didn't want to butcher my present setup so I grabbed a couple of fuses and started measuring. I broke the glass from the fuses and cleaned them out, cut the diode ends and sodered them in. Seemed like a pretty cool fix. I'll check the charging system tommorrow. Guess I could have made them a little longer. Moe in CT Share this post Link to post Share on other sites
rickv1957 76 #2 Posted February 6, 2010 Looks great! Rick Share this post Link to post Share on other sites
whfan74 2,073 #3 Posted February 6, 2010 Looks good to me.........will be interested in hearing if it did the trick for you. Nice job and seems to hopefully be a very inexpensive fix. B) Share this post Link to post Share on other sites
formariz 12,132 #4 Posted February 6, 2010 Ingenuity at its best. I have quite a few of the original diodes. I can spare some if anyone needs them.Just PM your address and will mail them free of charge. No stampedes now! Share this post Link to post Share on other sites
dclarke 4,107 #5 Posted February 6, 2010 great info moe, will have to remember this. Share this post Link to post Share on other sites
Michael Bullington 5 #6 Posted February 6, 2010 which diodes where these? great ideal!! Share this post Link to post Share on other sites
420lse 18 #7 Posted February 6, 2010 which diodes where these? great ideal!! I have to give Mr Ed Stoller credit for this fix. Go to the bottom area of this thread and it explains the diode concept. I simply added the fuse ends so I could more easily replace them if needed. Plus he explains how to check your system. It's a good read. http://home.earthlink.net/~edstoller/id11.html I did check the old diodes and they were toast. After I put the fuse ends on the new diodes, I checked them and they were working properly. I took the 655 for a ride and the diode replacment worked great. I didn't get to check my system with the multi meter (too damn cold today) but when I put my battery minder back on the battery, it was fully charged. Usually it's so drained it takes a few minutes to come to a full charge . Share this post Link to post Share on other sites
Save Old Iron 1,571 #8 Posted February 6, 2010 Moe, Check out http://www.aboveboardelectronics.com/keyel...copy/prod25.htm These are flexible vinyl covers which keep dirt and dust and direct splashes off the fuses and diodes. They should work now that your diodes are more "fuse-like" in appearance. B) Share this post Link to post Share on other sites
GlenPettit 1,718 #9 Posted February 7, 2010 We have the Remanufactured diode covers for these diodes, they are an exact match to the originals on the Wheel Horse with H's Tecumseh engines . . . . . See: Red Square Venders, GlenJeri Share this post Link to post Share on other sites
420lse 18 #10 Posted February 7, 2010 We have the Remanufactured diode covers for these diodes, they are an exact match to the originals on the Wheel Horse with H's Tecumseh engines . . . . . See: Red Square Venders, GlenJeri I have the original diode cover but I checked out your store and that's some quality work you've done there B) Share this post Link to post Share on other sites
