dodgepoorboy 0 #1 Posted January 27, 2010 hi all i just got a 1974 d-180 with a loader one question is where can i download a manual for it i try yahoo thing but is not working for me second question is i need to get a rebuilt kit for the cylinders that lift the bucket up and down but the cylinders have no numbers on it so how do i get a rebuilt kit? third question is how much weight can ones of these lift ? right now it wont lift its self off the ground i change the fluild and still nothing any ideas thanks everyone for the help!! rich Share this post Link to post Share on other sites
Rideawaysenior 28 #2 Posted January 27, 2010 Although the manufacturer probably did make rebuild kits for your machine, rebuild kits can also be obtained by taking measurements of the piston, and cylinder tube. There really isn't much to the pistons other then Orings and a wiper at the outside end and they are all pretty generic. It also may be worth your while to send it to a hydraulic shop and have them do it, as you should hone the tube and bottle brushes like what they have are on the expencive side. What I'm trying to lead into is, by the time you get all the parts and tools you need to do this, you might have spent enough time and money to justify a shop doing it. I sent out the two loader arm pistons to a local shop out by me and it cost me $60.00 per piston to rebuild. Just my two cents. Share this post Link to post Share on other sites
d180man 5 #3 Posted January 28, 2010 Hi i have some copys but my big comp is down right now but i know there is some one on here that can help but fill free tp pm me and i will get u a copy ! and i think the book list around 500 or 800 lb lifting and we love photos ! and we have to do the same to our loader we are going to just take it to a hyd shop and get the parts or just have them fix them !! :banghead: Share this post Link to post Share on other sites
rickv1957 76 #4 Posted January 28, 2010 I agree with the others that a hyd shop would be the best way to go,money well spent,Rick Share this post Link to post Share on other sites
dodgepoorboy 0 #5 Posted January 28, 2010 thanks for the info yes a manual will be great if u can help !!!! would u guys say if the pump is weak it will not raise it? i tighed belt one is glaze over but i sand papered it and it raises better im going to change both belts and see :thumbs: Share this post Link to post Share on other sites
pfrederi 18,966 #6 Posted January 28, 2010 Are you sure your loader hydraulic pump has two belts??? Most had one belt for the pump..the other belt maybe for the rear PTO. Is it a wheel horse loader or something homemade... Mine lifted much better after a new belt and tension adjustment. Share this post Link to post Share on other sites
