.5racer 15 #1 Posted March 2, 2008 Just found a meyers snow plow hose thats 45" long with 1/4" pie fittings.. Question is could the rear or mid lift cylinders be retaped to except these type of hoses. Can get them for about 10 to 20 here .Starret card says tapping 1/4-18 pipe to drill a 7/16 hole. Terry (racing Terry ) Share this post Link to post Share on other sites
kj4kicks 154 #2 Posted March 2, 2008 Might be easier to just get the adapters to go from the o-ring style to the pipe threads. Less mess, and easy to change back if you want to. Share this post Link to post Share on other sites
.5racer 15 #3 Posted March 2, 2008 Who carries them? :thumbs: Share this post Link to post Share on other sites
kj4kicks 154 #4 Posted March 2, 2008 I would go to a hydraulic shop, but NAPA probably also has them. Share this post Link to post Share on other sites
.5racer 15 #5 Posted March 2, 2008 been to NAPA . This is why Im asking about Meyers hoses ,everyone has them . Advanced,Auto zone, Car quest ,All shops supplying snow plow parts.... Terry Share this post Link to post Share on other sites
refracman 167 #6 Posted March 2, 2008 Terry WH used a 5/16ths pipe thread and a #5 hyd. fitting. With that being said your local Parker Hyd fitting outlet will have the correct fittngs. edit: if your 1/4 line has a #6 ( 3/8ths) fitting you will need a #6 female to #5 male with a oring seal to make your line fit. Share this post Link to post Share on other sites
