truckin88
K301 head gasket...what is involved
truckin88
All my C-120 could use a head gasket, as it is wet at the head bolts. This is the original motor, it probably has 2000 hours on it, been in the family since new. I ordered the head gasket, what is involved in this job? Anything normal hand tools can not fix. Any recommendations. Thanks. Motor is a K301
stevebo
Will,
So long as nothing is warped you should be able to unbolt the head, clean up the carbon on the piston and head then put the new gasket on and bolt it back up. You want to make sure you torque it according to the specs and correct torque pattern. Good luck-
pfrederi
Torque Wrench
Piece of flat window glass and feeler gage to check the head for warppage
rickv1957
If need be the head can be trued up easily,Rick
TT
How? :thumbs:
rick
I have done it with sandpaper and a piece of glass, not the most exact way, but it
has saved the day on a few "low budget" jobs.....You hold even pressure on the head as you move it in a figure 8 on the sandpaper, with the sandpaper on the glass. I don't say it is the best way, but if you are careful, it will work.
rickv1957
Or machine shop can mill and true head at a reasonable cost.
TT,I guess I should have detailed my post,Rick
