Shuboxlover 481 #1 Posted January 23, 2010 on my C-160 I have to jump across the solenoid now. I have an extra solenoid from my GT-1642, will this one work on my C-160? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted January 23, 2010 It will work, but before you change it, make sure you are getting battery voltage to the small trigger wire at the solenoid when the key is in the start position. You can check the function of the solenoid by touching a jumper wire from the large battery post side to the small terminal. WARNING: engine will turn over regardless of key position - keep hands & feet, and anything else you're fond of clear! Share this post Link to post Share on other sites
