PoolGuy
toro wheelhorse 416xt
PoolGuy
Hello All
I just bought a toro wheelhorse 416xt with a plow weights and chains and have a question about the lift height.The blade will only lift a few inches off the ground because it hits on a u shaped bracket on the front.The bracket seems to be there to keep the blade centered?
I was hoping some of you have had experience with this set up and could post some tips?
Thanks
Scott
rickv1957
Hello and :thumbs: Rick
Sparky
I dont have that style tractor Scott but the plow on my C-105 only lifts to just under 4 inches. I know thats not comparing apples to apples but thought I throw it out there.
Mike.......
rustynut
Umm can u put a picture of what your talkin about on
here so I can see if I can help u at all
Nick
Picture might help. Is the blade original or did someone make it fit?
refracman
I had to make a different lift bar for mine as the the one that cam in the kit was to short. Think it raised it up around 4in thou. I dont have it mounted this year as Im useing a 160 for plow duties now.
