snowbelter 0 #1 Posted January 20, 2010 the "BELTER" is down but not out the chain is sliping on the small gear the teeth are geting rounded. blower model#79361 ser.7900401 does anyone know the part #to the gear,is it a gear that can be mail ordered and whats the going rate thanks for looking. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted January 20, 2010 Prices are "rounded off": The small sprocket is P/N 117338-03 ($60) Big sprocket is P/N 116919 ($95) Chain is P/N 117447 ($40) partstree.com is one online source as well as a few others. Share this post Link to post Share on other sites
Kelly 1,033 #3 Posted January 21, 2010 There is a block of wood they use as a chain tensioner, the new one is plastic make sure that is good, or the chain will be loose and ride up on the gears, a new one is about $25 Share this post Link to post Share on other sites
bobert94 38 #4 Posted January 21, 2010 I had the same problem with mine. I bought a piece of plastic to replace the wood block. Drilled two holes in it and ground a radius on it to match the chain, been working for two years.Cost less than 5.00$ to repair. If your gear is two bad I would take it off and try to match it up at your local tractor supply store. The chain is a standard pitch chain and they would probably have that too.You would probably only need 2 or 3 feet and a master link. :thumbs: Share this post Link to post Share on other sites
JoeMonag 1 #5 Posted January 25, 2010 I just got my first Wheel Horse Two stge 79361, the directions are kind of vauge, about the wood block, Can some one give me some advise as to how to adjust it and when it should be repalced. An what is the p/n for the replacement plastic part. Joe in Norton Share this post Link to post Share on other sites
